dwcraig1
Everything posted by dwcraig1
  1. I'm only seeing 1_2_SP6_1 INT as the latest on my PC for either large or small screen DNA60.
  2. I assume that's a DNA40. Its the serial number of the board.
  3. With 2 cells the output of a DNA200 board is limited to 6 volts, 9 volts with 3 cells.
  4. If I was making something of that nature I would put a couple 21700's wired in parallel inside a box with a small charger.
  5. I use an old cartomizer with it's positive pin soldered to the threaded part. That could also be done with a 510 to 510 adapter. Setting it to 0.004 ohms would most likely put closer to what it would read. Most likely when shipped it was set to zero.
  6. I think he wants the one where Replay didn't work for you in Replay profile.
  7. I see no reason why it shouldn't work. Though I am confused with your theme settings/display.
  8. Save yours first
  9. Yes but you are in 316L profile, that's fine if that's what you want. I thought you wanted to use the "Replay" profile.
  10. Save your theme and try this one. Evolv DNA-C stock.ecig
  11. Look at the profile that I posted, that is correct for using Replay with any/all TC wire when not using Replay with Temperature Control at the same time. Your Replay profile should look just like that except for warmth settings and boost
  12. Here is my Replay profile. I am using dual SS316 Clapton coils.
  13. With your theme it will look different. After your puff is it asking to "Save Puff" ?
  14. When using Replay profile "Watts" is the material to select but you must use TC capable wire for the coil. In the TC profiles Replay can also be selected, in those profiles you select the material that you are actually using.
  15. If you see the resistance change in EScribe and Replay is activated on the profile and theme if needed and Replay still doesn't work then with a cold atty measure the cold resistance and try again.
  16. If your coil works in TC then it is most likely TC wire. Use EScribe's Device Monitor to see if the resistance of the coil changes when heated. My example is using SS430 wire which has a greater change than SS316, Replay must 1st be enabled in the profile in EScribe and use TC wire but depending on the theme it may need to be enabled their as well.
  17. Here is diagram from data sheet and this is how I did mine. I only used the one wire to #1, jumped the rest using small piece of wire or just solder
  18. I then switched back to Viable Coils and Replay failed to activate so I switched it back to Dubious and it is now working again. My opinion would be to use a material with a greater resistance change when building that low. Here is a great place for wire and coils: https://www.zivipf.com/epages/63862298.sf/en_GB/?ViewObjectPath=%2FShops%2F63862298%2FCategories%2FAlle_Produkte
  19. I had to change to Dubious Coils or Replay wouldn't work. Be sure to upload settings after changing to Dubious Coils. Just a small resistance change from cold to hot, from 0.196 ohms to 0.212 ohms. I changed to a stock Evolv theme for this as well. I used this one: Evolv DNA-C stock.ecig
  20. First off Replay box on profile needs to be checked. Depending on the theme Replay needs to be activated from there as well, this situation had me going nuts for awhile. Maybe save your theme and try another theme, coil wise I think it should be working fine.
  21. I suggest checking it with EScribe's Device Monitor. The screen really doesn't keep up as quickly. Note: The purple line.
  22. Are you seeing this in EScribe or on the mods screen?
  23. Is this been with all coils that you have been using or is it just with this one?
  24. A lot of good info here: https://www.e-cigarette-forum.com/threads/sxk-billet-box.898599/ By using Google Chrome for a browser you can get good translation by right clicking the post and select "translate"
  25. Only when using TC capable wire. As it should. But with kanthal or nicrome the resistance should be stable.
