Everything posted by giz_60
				HCigar VT167 (DNA250 Board) Only Showing One Battery in Escribe
giz_60 replied to Flyingdutchman's topic in DNA 200 and 250
Any voltage over 4.2x is a good indicator of a bad board/charging circuit. -
	Yes
	You may have an issue with the Theme...can you post your theme? In Escribe, go to the Theme tab...click Save Theme & attach file here...
				DNA250 lock 5x. first time user escribe
giz_60 replied to Critica1Err0r's topic in EScribe, Software and Firmware
Y Uou can only change the number of fire clicks (down to 3x, IIRC) to lock the device This will only help the battery indicator, fuel gauge, to be more accurate If a firmware update is available, Escribe will let you know and prompt to install -
				I know this isn't right...Therion 166 TC issues!
giz_60 replied to TorturedZen's topic in DNA 200 and 250
At only .01 - .02 rise in resistance from a cold coil to hot, it would seem that you are not getting enough of a rise in resistance. If the board doesn't see enough rise in resistance in the first second or so, it will drop out of TC. For instance, my current SS316L coil is .178 cold & rises to .210 - .211 after firing. Have you tried spacing your coils? What kind of atty? Can you post a screen shot of Device Monitor while firing, with the following fields checked...Power, Power Set, Temperature, Temperature Set, Cold Ohms & Live Ohms... -
				Looking for some advice on using Crown 3 TC with my DNA 250
giz_60 replied to Omega1397's topic in DNA 200 and 250
You can't use Ni200 material settings unless you are using the Ni200 coils...The info I previously posted was taken from Uwell's info on the Crown 3 coils & according to that info, the .25 & .5 ohm coils are better suited for wattage usage, not TC.... Edit:. Here is a response about a question of those coils found on another forum.... SS Coils on Uwell Crown have nickel legs, so they're to be used only on power mode because TC wouldn't read it correctly -
According to the info provided by Uwell on their coils, it seems that the SS coils you are trying to use for TC are better suited for wattage & the Ni200 coils for TC.... Uwell crown replacement coils use revolutionary food grade stainless steel. Standard 0.25 and 0.5 coils are made of SUS316 D-Grade Stainless Steel Heating Wire and use 100% Japanese organic cotton. Temperature Control coils are made with 0.2 Ni200 Nickel wire. 0.15 ohm (Ni200 – Nickel) 0.25 ohm (80 – 120W) 0.5 ohm (30 – 80W) -
	In Escribe, go to the battery section of the Mod tab & make sure that it is set for 2 cell....restoring default in Escribe restores it to Evolvs default...3 cells...
	Or...you could open a ticket with Evolv & let them guide you....https://helpdesk.evolvapor.com/index.php?a=add&category=1
	Samsung_25R_18650.csv
	The .004 is NOT a live resistance reading, but rather what the Mod Resistance that is set at via Escribe...@retird was trying to get you to set it to 0 to show you that
- 20 replies
- paranormal
 - lost vape
 - (and 4 more)
	You can also fill out a ticket with Evolv & let them guide you...https://helpdesk.evolvapor.com/index.php?a=add&category=1
- 20 replies
- paranormal
 - lost vape
 - (and 4 more)
	Sounds like there is a connection problem between the board & the 510 connector...seems it is new, I would contact the seller about a warranty exchange...
- 20 replies
- paranormal
 - lost vape
 - (and 4 more)
	If you have a Paranormal, there is a known issue with them. Read this post...it can also be causing the problem you are describing.....https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/
- 20 replies
- paranormal
 - lost vape
 - (and 4 more)
	Samsung_30Q_18650.csv
	Think_Vape_Finder_167.ecig
	One at a time...
	There are a lot here...https://forum.evolvapor.com/files/category/6-dna-75-color-themes/
	By checking the voltage in Device Monitor with batteries installed individually...
	Sounds like a bad connection on the battery sled...using Device Monitor in Escribe, you should be able to figure out which side it is on...
	No...Windows, Mac or Linux
	Others have fixed issues with the Paranormal 166 this way...
- 20 replies
- paranormal
 - lost vape
 - (and 4 more)
	If still in warranty, return to vendor....or contact Evolv & let them guide you....https://helpdesk.evolvapor.com/index.php?a=add&category=1
	It was originally found when Dec. rolled around & the devices were rolling the yr. back to 2016 when connected to Device Monitor...https://forum.evolvapor.com/topic/69318-problem-with-date/
	Hcigar_Vt_167.ecig
