Everything posted by James
Hmm. Is this new on SP12? What happens if you set MacOS to always show scrollbars?
What window manager are you using etc.? Is your configuration out of the ordinary?
The DNA 250 Color needs a battery attached to power the real-time clock.
Is this EScribe 1.2 or EScribe Suite 2.0? If the latter, try unchecking Service Packs in the installer. Does it help? Thanks!
@Twiq, SP5.1 and SP6 should be quite similar about charge resetting. Are you sure SP5.1 cuts out less? SP5 certainly would, yes, but SP5.1 should be the same as SP6 in that regard. It is self-protective functionality, detecting quick cut-outs of charge current that can be bad for the device. If it's doing it, it doesn't hurt anything, just annoying. (To be honest, I may have it overly sensitive right now.) PCs have fairly clean USB power supplies so you are unlikely to encounter it there. Does the charge resetting happen to you on other chargers you have? What brand/model of charger is it? 1 Amp or 2 Amp? -
@Pop7335, are any menus working for you at all? What window manager are you using etc.? Anything out of the ordinary?
Asking NEW or OLD coil every time I unlock device
James replied to Rburke2x's topic in DNA 75 Color and 100 Color
@Kurtis_Loew: 75 Color SP27 is available in EScribe Suite 2.0 SP8 or newer. (Look for the EARLY SERVICE PACK section. SP12 includes it.) -
What firmware version are you running/have you been running? Does it only ask about New/Old Coil with the most recent (SP27)? -
@Wayneo, what issue did you encounter with the install? Also, SP6 should let you read mod resistance quite low again. -
What error do you get when you try a manual update (Tools -> Apply Firmware) ? Also, which version of EScribe Suite are you running?
I've posted up an early firmware with Boost on DNA 250. Let me know how it works for you. -
I've posted a SP12 beta for Linux. Enjoy It includes SP6.1 for DNA 60 and SP6 for DNA 250, as well as usability improvements to the Theme Designer. Let me know if you run into any issues.
On Ubuntu 16.04, it turns out Ubuntu's global menu bar interferes with GTK 2 when I use dynamic menus. If you run the program with env UBUNTU_MENUPROXY= ~/.opt/local/evolv/escribe-suite/launch-escribe-suite it will work. The next release will do this automatically.
Turns out this is an off-by-one error in the real-time clock code affecting the month of December. (If you change your PC clock to another month and then run Device Monitor, it will work in any other month. It's related to PC-synchronized time, not on-device time.) I will be fixing it in the next Service Pack. Thanks for finding this!
@ekalle, all of those things work for me on both Debian and Mint. What sort of window manager, distribution, etc. are you running?
The folks on the Help Desk may be able to give you repair details. Did this just start happening out of nowhere?
If you are sure your batteries are fully charged and plugged in the right way, this could be a balancer issue. I'd suggest submitting a ticket with the Help Desk: https://helpdesk.evolvapor.com/
I've updated the SP9 download to make the auto-updater work on Linux. It now properly sets the execute bit on Service Packs it downloads.
On my DNA 75 Color (running SP27), Step Size and Swap Up/Down are both working. Are you sure you are uploading the theme? When you click Apply, you need to click Upload Settings afterwards to send it to the device. Also, if you want to swap the function of the Up/Down buttons entirely, that is in Mod -> Mechanical.
@HolmanGT, is your currently selected profile using Watts as a material? What you describe would square with being on a profile with Watts as a material. On monochrome DNA, Temperature Set is ? when temperature has been disabled. This is the default for Profile 5 "Power Ctrl" for instance. -
Try sudo chown -R andrikos /home/andrikos/.local If it created .local or .local/opt, they would still be owned by root. This is a good find. I've updated the installer to error out if running under sudo in the future.
Ah. I bet when you used sudo to install it, it created directories in /home/andrikos/.local/opt/evolv as root, which means you can't access them now. Try deleting those directories and then installing not as root. It's meant to be a double-click setup not requiring any special permission.
We don't do anything with IBus. That is related to your input method editor. Does the installer run properly? It will install to the Science group in the menu (often shows up as Other). You should not have to run the installer as root.
