OP did mention 'batteries' but the Therion 75 also came as a single battery squonker. So me not seeing multiple individual cells, made an assumption. Either way, that's a whole lotta difference in board temp and I stand by that post (except the single battery part.)
@jonnyw2k Those screen disconnects count every single time it's encountered, and resets itself to zero IIRC upon removing the batteries or a stats reset (old and can't remember). I can go weeks with 0, then a rash of them, then back to zero. The count is not erroneous.
@giz_60 Yet the Print screen only shows tick boxes for Pack, and not cell 1, cell 2. My bad as I don't own one.
Mystery 3000 mAh Efests, or old used/fake LG'sBoard temp at 60F higher than room temp in pic 1Board temp at 50F higher than room temp in pic 2And then Battery issues? You don't say. Sure sounds like battery is being pushed hard Kudos for the perfect Print Screens @Chunky it's a single cell.
The 75 So to clarify the Vt75 nano since the update reads as charged, then drops a couple percent off the first vape, climbs back up then drops off again. Am losing 20 - 40% of my batteries since the update, prior it ran from 100% down to about 12%. - The drop then climb is normal as the battery comes back to its resting voltage. Do you notice there's MUCH less sag on your 200 image(which is a bit unfair comparison). I wish you could put your mouse pointer on the low point after firing, you'll probably see your batteries are hitting the cutoff. Good call on replacing it. The 200 The Vaporshark runs a Lipo 3S 9volt, the first battery killed off a cell after about 8 months of use, the new battery an exact replacement, seems to jump from 80% to 100% on the charge and never charges above 4.12, all other ( non lipo) batteries seem to charge to 4.20. Then the battery on first use will promptly drop to about 78%. <- Can you check if yours is set to max charges or max puffs (mod tab)? Maximize charges will only charge to 4.1 volts but gives you close to twice the battery life. Because of that your watt hours are out, hence the inaccurate %.
@buellbloke That update you downloaded was probably just for Escribe, and not firmware for your mod, which was probably at the latest June 2016 version. What do you mean 'bugging out'? What kind of battery, and what's your 'cell soft cutoff' set for?I don't understand what 'always felt the vape on the DNA200 in TC with nickel was lack lustre. My batteries could be getting old I suppose' the VS200 is a Lipo, but a Device Monitor Print Screen while firing would answer so many questions. I can't recommend what options needs to be checked without a bit more clarity. But no worries, you're at the right place.
So for a 2 month old "HCigar VT250 battery display issue" your quality recommendation is: #facepalm, but thanks for coming out.
@gogo No need to be desperate. SS is very safe to use in wattage/kanthal/regular mode. I'd suggest you follow post 16, then some youtube videos about your mod/DNA device, get comfortable with it, then worry about TC vaping .... you'll get there. Relax and have a vape.
You do realize there hasn't been an update for this since 2016-06-05 and your computer capture shows 22/12/2016 which is when you probably downloaded it onto your PC. I think your mod already had the June 2016 firmware (based on release date of the Nano), and something else has happened. My only thought would be to clean all your mod connections and battery ends, make sure they all seem solid/snug.
Exactly, just like has been noted with the 2 dash 3, and unlike the efusion where it's a solid XT30 plug/unplug.
Duo is nowhere as quick or easy to swap. Got one, love it, and I've never put in the Lipo. Leather has now worn to a dark rich brown.
So everytime you want to change from 2 to 3 cell mode, you have to go into escribe and change battery parameters. Uh huh
Under "File" menu, go and save a copy of your entire settings in case you ever need to restore back to pretty close your 'standard'.
Good idea. I'm assuming your 'pinch' means removing from the VT75 and testing, and not actually pinching which is also an issue on some mods. Restore from the latest backup you saved.
Damian, my feeble attempt at some old time IT humor. In the old days it was PEBKAC, so to keep it current and relevant, I've now invented (Problem exists between mod and user).
Go to your Goblin profile, save that profile, go to your Merlin profile, choose 'load' and select your known Goblin profile. Rename profile text display's back to Merl or whatever Whole lotsa PEBMAU. For TC to work properly, both the mod and the atty need to start at the current room temperature. Ya can't just willy nilly swap 'em out. Yes for Power/watts but not TC Excellent descriptions that you provide allow for quick(er) diagnosis.
@jaygee Hereâs an excellent MacOS native monitor for DNA devices. Super fast, and quick. https://github.com/hobbyquaker/dna-monitor I find the display is much cleaner once you stop your vape, compared to escribe I have seen those âdropoutsâ infrequently while running escribe via Vmwareâs Fusion product, but only with 1 of my many DNAs. I think my only 75, but Iâm old and forgetful. That was one funky image you posted. Edit: In looking at your print screen again, could you humor me with one more at the following settings. No preheat, no punch. 25 watts. Same coil.
@Smil Your batteries show they're hitting your soft cell cutoff under load. Follow @giz_60 suggestion. When you say this "... My other "Non-DNA" Boxes drain the batteries to 5% - 0%" what is the voltage remaining in them? "I dont know whether the Volt drop is normal" This is different for every mod depending on its ability to pass current from battery to atty. Quality of battery, wires, connections etc. all play a role. If your concern is really that "15% value" run your own battery analyzer
Nope, and a lower ohm might suit you better deprnding on your power/heat requirements due to the 6v limitation. I believe 3 other factors enabled your success. You used a different atty. You created a single coil build, and you raised up your power levels. I think both giz_60 and I leave our settings 'high' to accomodate any build and let the board do its job. Others like to fine tune down to have a bit of headroom over what the coil actually requires in case of careless mistakes. You can pick your poison.
Was your coil description accurate? Dual coils I presume?Did you remember to upload (the material and profile settings) to your mod?If that's 3 "yes's", can you post a printscreen of your profile and device monitor while firing. Ensure you have the following 'checked'.
