WOW!! What a mess. Mod Res at 0, Lipo battery curve, non-optimal sc cutoff, definitely wrong Wh's set. All that with 62k puffs. Is this a used, but new to you mod that you've been 'playing' with?
Vaporshark DNA250 escribe softwar issues
Wayneo replied to kevmat's topic in EScribe, Software and Firmware
Well, manufacturers should run a few of their units through testing to come up with the Mod Resistance for the units. The more accurate this is, helps with temp control, and other interpolated values. If YOU want, you could run it yourself for your specific mod, for the most accurate value. VS is a highly respected company, so I don't think you'd find much difference, so it's not a must do. All in all, I think you're good to go. -
@arzhaq Yes for ALL DNA's that use escribe
Issue with custom temperature profiles
Wayneo replied to uberbdon's topic in EScribe, Software and Firmware
How can you be at a loss. Your first Device Monitor shot showed you were in Profile 3, your second (which matches with your profile setting 5) shows it works. Edit: excellent screen captures. Makes helping so much quicker. Beautiful solid TC you got there -
@darth vaper, with all respect to @stevef I'd suggest different changes. The beauty of the DNA is you can test and monitor both easily. I'd suggest 2 things. Using the profile you showed, I'd raise your punch to 11 and time to 2 seconds. It looks like a staggered fused clapton you have, so by increasing those 2 items, although you have 2 seconds, punch 11 will stop your pre-heat once you're within ~10F of your set temp. Try both and report back, please.
Therion DNA133 unable to modify LED indicator
Wayneo replied to crazirvd's topic in EScribe, Software and Firmware
Yes @oddly.orangre. -
Whoa, pictures with all that blur/jitter, but made it out. I see you're never even really coming up to temp. Can you do a print screen of your profile 7. With Device Monitor showing you just hit the "prt sc" button on your computer or (if you press [ALT]+[PRT SCN], open MSPaint and paste [CTRL]+[V] you have a screen shot from any program, that you can save and upload)
@Darth Can you post a Device monitor screenshot with at least the 2 temp boxes checked, and another of the profile, please.
Lost hcigar vt200 charing cable
Wayneo replied to 1058808's topic in Connectors, Components, and Accessories
It'a a standard data/charging cable. Buy the thickest one you can find. I assume your lost cable WAS working the last time you used it. I also assume, you've tested whatever you plug into still works with those other cables. -
You can 'prove' your beliefs in Device Monitor, and carry on from there. Great little mod that SDNA75, I just wish it were 2mm wider.
Triade DNA 250 Temperature Control Stopped Working
Wayneo replied to Quagmicah's topic in EScribe, Software and Firmware
Yo @Quagmicah, have you tried one of your multi-core fancy builds as a single coil, with ohms unlocked? Room temp atty on a room temp mod to start. You might be pleasantly surprised. @NayBray what do you mean by custom curve and temp is out? Can you do a 'print screen' when you start (pack, temp, temp set, cold ohms, live ohms enabled) and it's good, then another when it's no longer good. -
Excellent for you Nasos. What do you mean by better in watts mode?
Now I personally think is very silly. If one has a decent mod, the manufacturer settings are unique to each. Why would anyone want to put the wrong settings on their own?
Answered in the other thread.
... this is a confusingly labeled 3000mAh battery with only a 20A continuous discharge rating (CDR) - from the master. And NOT on his recommended Battery List 9/17/2016
im new thereion 133 user. Battery issue
Wayneo replied to joseph1203's topic in Batteries and Charging
Hoping for a faster reply ? Real reply deleted. And I notice your question is completely NOT acknowledged or answered. My LostVape Efusion Duo was properly setup from the factory, but I see many posts now where many fields are blank. And the admins are far too kind by allowing this, and not deleting one. -
Device Monitor for Apple macOS (native)
Wayneo replied to hobbyquaker's topic in EScribe, Software and Firmware
I'm on 10.12.2 and had a few similar type issues at 0.9.2. Now, at 1.0.0 no issues encountered. -
@hobbyquaker I'll probably just make my start page github. From 0.0.6 to 0.2.0 overnight, and now 0.4. By the New Year you could be up to v1.0 What's really interesting (SS316L, .379, 420F) is that the board, based on the linear temp ramp up, has already started throttling back the power at ~.25 seconds, sees the temp ramp drop so it blips the power back up to hit the temp, then a more gradual drop in power. Excellent work you're doing there. Are you actually sending your commands serially and waiting for the response as suggested. I can't see escribe doing it in that manner.
Lost Vape Triade DNA250 lost settings
Wayneo replied to coldmantis's topic in EScribe, Software and Firmware
@ritzroscka Wait a few hours and you should be able to download once it works through their systems. -
@VapingBad Just a very minor question. I was always under the impression the 200 is 97% efficiency, and the 250 @ 98%
@hobbyquaker Super thanks there!! I found and downloaded, and started using it yesterday. Works as intended and I don't need to fire up any sort of virtualization software. Slick. I've tested straight wattage mode as well as TC mode, 4 different mods ranging from 75's, 200's, and 200/133. All perfect. It would be nice to 'enable logging' and save a csv. One question .... after clicking on highcharts, how do I get back to your regular display? -
YOUR CSV should be perfect for YOUR battery. Since battery life is the issue, perhaps someone should chime in on the "Cell soft cutoff" value. In the meantime you could use the "Search" option up there. ^^^^^^
Gents, while the problem is real, there was missing/vague information. First off, that photo does not match any Lost Vape product and it's certainly no Triade 3 battery mod like the video or the photo. It's a 2 battery Thinkvape Finder 167 I bet. Then again, the OP's vagueness never did say it was, nor was that ever clarified. If it is pretty new, the place of purchase would be where to start, and they should repair/replace that for you.
EScribe Custom Battery Test Python Script
Wayneo replied to VapingBad's topic in EScribe, Software and Firmware
