  1. Charge and discharge before rushing out for an expansion pack. Can you source the housing and battery seperately.
  2. Meh. Recovery charging stops/times out. Just put it in regular rotation and charge it. I don't charge anything overnight.
  3. I don't work in the industry, so now I'll go out on a limb. I thought it was interesting to see a 200 with such so low puffs. It smelled like a Lipo, from your post. You verified a 14 month from board programming. Here comes the jump. Volcano had a big sale and either had a crap load of boards and batteries sitting there or already assembled for a long time. Nothing you can do to prevent the imbalance. It could just be an old battery.
  4. Nice, see right now you don't think I'm whacked. Escribe - general tab - get information. When was that board programmed? And can you do a printscreen .......... while firing. Normally, I only see like a +/- .01 on a new fresh Lipo, if it all, during firing.
  5. Sometimes you have to do a recovery charge multiple times to get them all back. Vape it down, then recovery charge if you wish? Is it a Lipo battery? I could go way out on a limb but then you'd think I was whacked.
  6. If you vape your mod down, during charging, it might bring all 3 back to the same voltage over time. Leaving those same checkboxes ticked, you can vape it and see if Cell 1 sags more than #2 and 3. Having 'pack' ticked you can undo for less clutter. Do you remember what the lowest cell voltage was when you started?
  7. That soft is the keyword. Many here safely set it to 2.7-2.9V, so wherever you feel safest.
  8. 'Capacity' only relates to battery icon. 'Max Peak/Sustained Input' is already maxxed out IIRC. What are you seeing at 3.5V? Run Device Monitor with cell1 and 2 ticked and see if there's alot of sag on the cells, or 'a' cell. Post printscreen here.
  9. Over on the left, Cell 1 is .04v lower. That's pretty cool with only 2 non-TC puffs, I've got one mod with I think only 1 non-TC.
  10. Not sure what this was in relation to, but great. Just in case TCR/TFR only relate to Material type. It does not change due to ID, or wraps, etc. They posted it on their FB page, in the August timeframe. Don't quote me on August, I'm old and Grey
  11. Well ............... I'm out. But welcome
  12. Protovapor.com - USA, or modmaker.co.uk - UK, if you must. If you don't want to send it back to the vendor for whatever reason, you could open a ticket with Evolv (USA) but using your predicament, you might still have to claim full price. In my country if it's a warranty/broken item the value is effectively zero. Good luck with your choice
  13. On the DNA, there's a feature called refinement, which (based on a couple factors) will interpolate what the resistance would be at 70F. Once your mod fires it could take up to 30 minutes for it to have that refined value. Or when waking up from a dead sleep. That refined value will not change much. Maybe +/- .01 and will NOT change on your mod while firing. If you're a fan of the FSK, get a spare while you still can. They're now a part of Indonesia Chemistry. No more mods. You should be able to run your .05's on this box also, but you'd have to check on steam-engine, knowing all 4 constraints. Current (Amp) limit and output voltage for your particular board. Page 1 of datasheet. On Device Monitor, you can see the exact watts required to maintain the temp you set (green lines) Oh yeah, welcome
  14. I have the solid Black. Hadaly now sits. My only issues are juice pools on top of the clamping/airflow an underside of the cap. Usually 2x28/40g SS. .2-.4Ω Next up will be a Ti01 build to see if it decreases the pooling. Definitely not, and just the opposite. Therions before the 'C" version had a ~6v ouput voltage limit. Yes. Steam-engine (wire wizard). You can either dowload a TFR, or TCR then import on the Materials tab. I'd suggest you download a new version of 316L from there, but name it like 316X. Change all your profiles the X. Delete old 316 profile. Upload settings to Mod. Start with a preheat of 100W, say 55W regular. If that works, we can fine tune it. Can you do a Device Monitor like the one below (while firing) , with exactly the same checkboxes highlighted. Temp less than 500F, or whatever you think you're accustomed to.
  15. Can you describe your build? Are you making sure your coil has reached ambient temp before using on the mod, and checked all the connections are tight. I never owned an FSK mod, but on DNA's you should NOT need to lock the resistance normally
  16. I do not own a 75C, so these are some thoughts. Have you updated the firmware to the latest version? N80 has too low of a TCR to be used for Temp vaping. Only watts/power mode. BUT, if it could, Material Tab, left window and import it in or create a new TCR value material and name it. Right arrow to put it on the mod. Upload settings to Device.
  17. Folks, this might be of interest.
  18. Well, ya got 2 choices. Escribe - Tools - USB Recovery charge (but you'd have to do this numerous times, and look if the cells will come up in V) or an external charger. However, depending on how long they've been that low (1 and 2), there could be bad internal battery damage. Just replace with another battery. Any idea why this happened (shelved and unused for a while)? Edit - Added this -> If it were mine, I'd just replace the battery
  19. Is that a Lipo? If so, the cells are highly imbalanced.
  20. Many squonking/BF 510's have an adjustable 510 pin to ensure a solid connection.
  21. The 75's never had the same battery smarts as the other boards like the 200 series.
  22. In escribe do this Options -> User Interface -> Advanced so the 'Mod tab' shows for Atomizer Analyzer and battery changes Change # of cells from 3 to 2. Your mod should now work. You've lost any logos, setting setup, and any values that might have been setup by them.
  23. I've seen some of his where they were named like soft, medium, hard, no preheat, etc. If you liked/used those (which are still perfectly fine), then with your red text, you end up choosing the type of profile and change material only. OR You set up specific profiles based on material/wire, and use that for a complete setup. Personally, I use a combination of each on a mod where it's painful to get escribe access.
  24. Rasta, there are 2 different ways. Your RED text above allows you to change materials 'on the fly' and follow the preheat, punch, time, watts set for it right now. Used if you want a soft, medium, hard type settings. To change to a new profile completely (like your 316 profile); hold up and down button at the same time till screen displays message quick double click either button (displays current profile name) click either up or down button to change to next complete profile click fire button once you reach the profile you want hold up and down button at the same time till screen displays message If you followed your red text that can happen.
  25. Seeing as how @James gave you a method, here's a touch more detail. Steam-engine, wire wizard. Use material of your choice, click equivalents, put in desired temp of your test. In new material type, use the same wire profile, it will show the resistance required for that temp. If I'm wrong hopefully someone else will chime in.
