Complete Noob. No new User Guide? Questions Inside.
Wayneo replied to GloriousBeardGuy's topic in DNA 250 Color
You are correct. There is no new user guide but one suggestion is to go watch a couple youtube videos on the DNA board/mod. DJLSSBvapes has quite a few, or a technical reviewer. You will get a better basic understanding. Questions #1 and #3 are both theme specific, you need to read the 'about this file' section for that file, and IIRC he used the trem 'throttling' instead of the official 'temp protect'. OR, you could just comment in that theme and get a direct reply from the author. Back to question #1. Yes, one could/would be the preheat watts. Question #3, check all your connections are solid, and the stability of your build using 'Atomizer Analyzer' for that coil, in escribe. -
That's a lot of mass you're trying to heat at only 28 watts. In straight watts, how high do you vape that build normally? I'd set your watts in TC mode (profile) at that value, then adjust the temp to about 200°C to start A snippet of Profile 8, and Device Monitor would be good after those changes (and unclick/deselect those 4 checkboxes below the graph portion) Out of those last images the first was much better than the last 2 for me.
Did you ensure the screen cable bend was away from the fire button? If you follow the link you'll see what I mean. Otherwise you might end up needing another screen after a while
Turnigy LiPo 950mah 3S 11.1v Curve
Wayneo replied to shehabismail's topic in EScribe, Software and Firmware
@shehabismail Duplicate posts are in no one's best interest. Your duplicate post has been hidden But to add, you can also run your own discharge profile. Hope this helps. -
My experiences. 1. I'd say IF your atty is making a solid connection would be most important. Money does not always mean quality. I have swapped out 510's due to them being shitty and it was expensive. You can check the stability of your atty connections using 'Atomizer analyzer' in any profile. 2. If he followed the spec sheet he should be fine for the wires. As well as good soldering connections. 3. No. Make sure you're using a proper TC capable coil as the core wires for Replay
I'd say proportional based on factors as opposed to incremental. And Yessir! You can use 'Device Monitor' with the power options enabled to see it clearer. If you put your mouse over a peak power and click, it will draw a vertical line with the relevant values.
Themes are merely skins to escribe. If you start escribe, while looking at the various Profiles, if you hover your mouse over many fields you will get the 'official' definitions. Here's my 2 cents Boost - Only used for any coil NOT in TC. Like a kanthal power curve, or preheating the coil. The term 'Preheat' is only used if you're talking TC Punch - 1-11 value for extra power applied for 1 second Watt Boost Profile -Profile that allows you to set/change/use the above. DJLSB Vapes has some good Youtube videos
How to change a screen on LostVape Paranormal
Wayneo replied to JacobEvolv's topic in Manuals, Instructions, and Tutorials
From before the release of the color capable boards some users would put a very thin film of colored plastic film over their mono screens to change it from b&w. And yeah, LV would know for sure. I hear they're active on facebook and Instagram -
Hcigar VT75D reset problem, help needed.
Wayneo replied to Edwin1967's topic in DNA 75 Color and 100 Color
If it's not a battery problem, or a connection issue, I'd suggest you open a Help Desk ticket for an RMA. Link below https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
What do you mean by resets. (Mod stops mid puff and goes back to locked state, or what) And afterwards what needs to be done -
From within Escribe ....... Can you post a 'Device Monitor' and a Mod - Safety tab printscreen And which vapestation are you using and who built it
Paranormal Fire button works, but not when Smok tank is attached
Wayneo replied to mallen108's topic in DNA 250 Color
Smok were notorious for having long 510 pins (crushing or shorting wires below), and if even if your mod is repaired, (if that's the issue) it could happen again. I'd suggest you open a Help Desk ticket for an RMA. Link in my signature line. -
Try those, or even the Smok not fully screwed in. -
Do you have anything that is not SMOK? I have never owned anything SMOK so I just don't know. I'll edit your title in hopes that someone else will chime in. -
What mod, what tank? I realized that if the tank is off the fire button works like normal <- So the coil and connection are still attached, but no glass or ejuice? I started screwing in old tanks and it's the same for all of them. <- Is any error displayed on the mod? The more descriptive you are about the problem, helps in our understanding of the issue. Welcome. -
Does that change if a data/charging cable is plugged into it?
No idea, I don't work here/there. BUT you can always open a Help Desk ticket and officially inquire. Link in my signature line.
Psyclone SqEvo dna60 is saying OFF when trying to use temp control w SS
Wayneo replied to William Balagna's topic in DNA 60
Your duplicate posts have been merged and moved. The navigation key combinations are exactly the same as on the 75 you have/had. Let's see if I hit all your issues. Using escribe 'Device Monitor', bottom line you can see what profile you're in. Using escribe you can choose ' temperature dominant' for the big temp, in any profile you want. Using escribe When the mod shows 'OFF', make sure you have a TC type material(SS in your case) for that profile chosen Upload settings to mod. -
Here will always work better than there.
So much for reading your own post on reddit where I already answered all these questions, 10 hours ago. Reddit answer: Material(wire) profiles don't care about build specs, or wraps. Only the wire itself. And even on a color board you can't 'type in the TCR on the go' SO 1 Material(wire) profiles don't care about build specs, or wraps. Only the wire itself. 2 Rename a Profile Kangar, put in those preheat, power, and material type 3 Material(wire) profiles don't care about build specs, or wraps. Only the wire itself.
That was your original question. I read that as 'Can I use a DNA60 small screen with a DNA75' That answer is no because there is no firmware option/support for the 75 with a small screen (like there is with 60 board).
Handy Coil Factory V2.0
Wayneo reviewed Handy Coil Factory's file in DNA 75 Color, 100 Color, 250 Color
Contact the modder and ask, but for now, refer to this post for workarounds.
