  1. Wayneo
    TC help
    There are many newer YT videos about the boards and escribe. The concepts for the color boards are all the same. DJLSB vapes has some good videos. If you look at each of the 8 profiles you'll notice that they each have an ohm value and a room (ambient) temp it was read. Some themes will allow you to adjust that temp, but it's not on the default theme.
  2. Wayneo
    TC help
    Yes
  3. Wayneo
    TC help
    Sure. I'm usually in the 390-480 range. Hopefully you understand what I looked at. 😉
  4. Looks like it, when I read his words
  5. Wayneo
    TC help
    Sure, raise the temp if you want. The warmth to you is subjective. I, at times, vape higher than that and sometimes lower than that depending on the flavor I want, or first thing in the a.m. Sorta. Your mod started at zero, shot past 50 (green line again) (due to preheat watts power), then settled at the temp set. I have no idea about last week, could be anything. The room temp issue is tricky at best. You'd need to run a thermal calibration. Takes about an hour, and it's then modeled. However there are about 4 different scenarios where depending on what's going it can affect it. You could always use Profile 8 Replay.
  6. Escribe, look under the far right 'Help'. Your mod's been saving backups. Failing that, have you tried the 'search' Welcome 👋
  7. Wayneo
    TC help
    On the surface, everything looks fine to me. Well, the room temp appears low, but only you know if that's in the ball park. TC appears to be working as it should (red line). I see your cold ohms rise(purple), and the mod regulating the watts as it should (green line). How does it feel to you?
  8. Bill, there's a very trusted vendor that has created 4 free battery profiles available for anyone to download. 3 show a 0% battery life remaining at 2.95V But 1 shows a 0% battery life remaining at 3.61V and it's been downloaded numerous times. I checked again just now. 🙃 Hmmm, nope. 🤔 There is very little to no sanity checking done these days by most IMHO. I'd run my own.
  9. My Mirage DID NOT have the same internal resistance as Jason's in that file. My 2 Paranormals DID NOT have the same internal resistance My 2 Triades DID NOT have the same internal resistance I check and set with my all shined up Copper tool before ever taking a puff. For every mod I own. PS That red tool, available on Amazon is great for cleaning 510's. Fiberglass threading you snip off when dirty.
  10. Only in bizzaro world could a person think that from what I wrote 🤣. I still think it was just 'boost' not enabled initially. In this case I DO recommend the Evolv 'manufacturer' defaults over those from a user created file, that's not even a Dovpo product. In all fairness I did post the Dovpo Mini 'default theme' last year, and after >350 downloads not a single comment or review noticing that their Ohms too low/high messages were backwards 🤣. Hey it's their default. With all the tools available to end users I promote users to run their own for their setup. A quick search here shows at least 20+ times. 😉
  11. Wayneo
    TC help
    TC requires that you start with your coil at ambient (room) temperature when you measure the Ω (among other things). Replay is much easier (on the standard Profile 8 (Replay)) where you just save the puff you like, for it to follow. If your new coils are similar, and close to the original Ω's, there might not be enough change for it to prompt the 'new coil' message. So you could/should remeasure before vaping. A screenshot of Device Monitor while vaping showing watts, temp set, temp, live and cold ohms would help
  12. And here comes the real counts, fellas. SirTimmy added to the list and it looks clean back to and including the 14th
  13. For every theme on that front page 'TOP PANEL', I'll GIVE THE COUNT ON THE THEME FOR THE PRIOR DAY, MAYBE AS A REVIEW OR A COMMENT. When a NEW theme shows up, I'll do a deep dive of how it got there, starting on the 21st. Download Stats for April 19, 2021 Sorted alphabetically. Designer named. @ Commodoretheme. Downloads 0 And now hidden by poster. @ Frank65theme. Downloads 4 @ Khaled shehabtheme. Downloads 1 @ Mr. Bottomfeedertheme. Downloads 1 @ Skittheme. Downloads 2 @ Stepladdertheme. Downloads 10 @ zarktheme. Downloads 2 Yearly TOP panel. Designer unnamed. unnamed 1 theme. Downloads 5 unnamed 2 theme. Downloads 2 unnamed 3 theme. Downloads 6 * The entire listing of 7 plus the unnamed 3 includes every single theme that is on the weekly, monthly, and yearly 'Top Downloads' panel.
  14. 15 watts on ALL mods SHOULD feel the same. All things being equal (between your Odin and the Thelema), the 'boost' will be the same for YOU. It does not matter 1 battery vs. 2 or even 4 for your specs. There are many good youtube videos that explain the features of these boards. Here are 2 screenshots for you with similar coils. One a lowly 75C, the other a 400watt capable 250C. Look at max power. 75C 250C I think it was just 'boost' not enabled initially. Enjoy your mod. 👋
  15. Gents, just a bit of commentary. For starters, those that have been here and getting notifications have noticed that 2 posts have disappeared. Each was hidden by the respective author, not me. This post has a singular focus, to stop download count spamming. That's it, that's all. This forum is rather unique, I can't think of any other board mfgr. that caters to their users like this one. I can think of two barely similar that have been completely overrun by spammers. It's too long to go through and quote comments but I'll just say this. It is clear that some registered users will just go around 'theme collecting' 4, 5, 6 at a time. There's nothing wrong with that.
  16. Every theme on that front page 'TOP PANEL', I'll GIVE THE COUNT ON THE THEME FOR THE PRIOR DAY, MAYBE AS A REVIEW OR A COMMENT. When a NEW theme shows up, I'll do a deep dive of how it got there, starting on the 21st. Download Stats for April 18, 2021 Sorted alphabetically. Designer named. @ Commodoretheme. Downloads 5 @ Frank65theme. Downloads 11 @ Khaled shehabtheme. Downloads 2 @ Mr. Bottomfeedertheme. Downloads 1 @ Skittheme. Downloads 3 @ Stepladdertheme. Downloads 2 @ zarktheme. Downloads 1 Yearly TOP panel. Unnamed downloads Example 1 theme. Downloads 2 Example 2 theme. Downloads 2 Example 3 theme. Downloads 9 Summary: No spammy downloads for any of the named 7, plus 3 unnamed.
  17. Every theme on that front page 'TOP PANEL', I'll GIVE THE COUNT ON THE THEME FOR THE PRIOR DAY, MAYBE AS A REVIEW OR A COMMENT. When a NEW theme shows up, I'll do a deep dive of how it got there, starting on the 21st. Download Stats for April 17, 2021 Sorted alphabetically. Users named. @ Commodoretheme. Downloads 1 @ Frank65theme. Downloads 3 @ Khaled shehabtheme. Downloads 3 @ Mr. Bottomfeedertheme. Downloads 0 @ Skittheme. Downloads 11 @ Stepladdertheme. Downloads 3 @ zarktheme. Downloads 3 Yearly TOP panel. Unnamed downloads Example 1 theme. Downloads 4 Example 2 theme. Downloads 3 Example 3 theme. Downloads 5 Summary: No spammy downloads for any of the named 7, plus 3 unnamed .
  18. Every theme on that front page, TOP PANEL, I'M GONNA GIVE THE COUNT ON THE THEME FOR THE PRIOR DAY, MAYBE AS A REVIEW OR A COMMENT. When a NEW theme shows up, I'll do a deep dive how it got there, starting on the 21st. Download Stats for April 16, 2021 Sorted alphabetically. Users named. @ Commodoretheme. Downloads 1. @ Frank65theme. Downloads 9. @ Khaled shehabtheme. Downloads 1 @ Mr. Bottomfeedertheme. Downloads 4 @ Skittheme. Downloads 5 @ Stepladdertheme. Downloads 3 @ zarktheme. Downloads 0 Yearly TOP panel. Unnamed downloads Example 1 theme. Downloads 3 Example 2 theme. Downloads 3 Example 3 theme. Downloads 13 Summary: No spammy downloads at all for any of the named 7, plus 3 unnamed. * 2 registered forum users went around 'theme collecting' and showed up on these stats more than once.
  19. @gwyar When a post contains both German and Ukrainian, or both German and Russian, Chrome cannot translate both to English easily. It's manual for me. (Any one) and English is easy. I appreciate you doing when it's just German and English, but not necessary. From a 'work' perspective, I think it's quicker (time wise) for me to do it.
  20. Guys seriously, way way way back on Page 1 I referred to @zark as the unofficial theme critique master. Like you, I really only use 1 theme, mine. A warmed over tweaked, colorized version of the default. I just wanna vape. I don't want a bunch of useless shit on the screen unless I'm having a problem. I've used 'clean colors' when that very helpful designer was new, mainly to steal the font. I've used Mr.Bottomfeeder's to help with all the English translations, and the native English 'about section'. Another good theme, worthy of being 'featured'. But I always gravitate back to my own. I see visual creativity in everything by SirTimmy, but I'd say, 1 has been on my mod for about 5 minutes. Nothing wrong with it, just not my style. Seriously, beauty and creativity is different for everyone based on their likes and needs. I see many get a good review and it's all about the cool wallpaper. Here, I'll load up Gwyar's soon.
  21. Holy jeebus. Once a user creates a theme, reviews can only be commented on by the theme owner for it to stay intact. Occasionally one of us will comment back to the user if it's a somewhat abandoned theme. Reviews are more like a personal conversation with the author. In the regular forum, here, all 3 moderators are very involved. I think I've only ever commented on two or three themes before this incident. Wouldn't a bad review from a moderator on any of your themes really really piss you off?
  22. Chrome's translate does not work when a singular post contains 2 non English languages, so I've been back and forth manually. Just asking if you guys wouldn't mind doing one translation to English on your end. Please.
  23. Man, we're just 3 volunteers. We do have the ability to 'pin' a Theme, and we 3 decided to pin one, when we saw this crap getting out of hand to bring a little recognition to a good helpful designer who also has a good theme. Just click the Downloads link. Not theme park or anything. That's been there a while and should be refreshed. It shows as 'Featured Downloads'. I really don't think we 3 inspect, verify, use many different themes. Maybe change the default?
  24. @Skit Please self edit your post. Leave only positive thoughts and suggestions. For about the gazillionth time this must remain respectful. Please and Thanks man 👍 Tomorrow you will see the downloads for each of the 7 (for the 16th), and moving forward, HERE.
  25. Unfortunately one can only use 8 rudimentary sorting options when looking at the 1,116 themes on the board. And just like many users never change/select the 'any' default regular search criteria, to 'all', in this instance they don't (in my opinion) change from 'recently updated' for Themes. Look at the options, is there a better option? Would it be good to make every downloader have to sign up, and request they leave a review? Under the About File for a theme should we request every Designer ask users to do the above, before making the public? Should I/we add that text to any theme that reaches the Top Panel if it's not there? A good designer interacts with both commenters on his theme and elsewhere. I see that often from a handful of you guys. The standard Top 5 all did that at some point. Being helpful to other Designers. I have respect for all those true Designers, you and @gwyar @Mr.Bottomfeeder@Jetro @formula 1 all included. IMHO a good theme should be simple in style with complexity in its execution. Look at vaping right now. Auto draw pods. No screen at all. A tiny % even use TC or Replay.
