This theme is now called "Clean Colors" (used to be "Clean Black and Blue"). This is because I am now offering many different color options (see downloads page or screenshots below). (The lightning bolt on the battery is only visible while charging)
  • Just added a ONE WATT version for those who want one-watt increments on the main screen. Currently it's just the blue theme, but if there are other color requests let me know (see downloads page: Clean-Color-Blue-ONE-WATT-#_#.ecigtheme)
  • Replay ready! (TC and wattage modes available too) - See below if you are having trouble with Replay
    • Replay available on the Main screen, and there is also a Replay settings page with more info if you need to diagnose Replay issues
  • Note the screenshots are a little misleading. On the Main screen, the battery icon only has a lightning bolt when the device is charging
    • See screenshots below for how Main screen normally looks
  • You can hide data on Main screen in Display settings (resistance, voltage, etc)
  • You can hide time from Lock screen in Time settings (time always resets for me when I change batteries so I like to keep it hidden)
  • Battery info page, and for supported devices (250c): voltage reading of each battery cell and power bank options with enable/disable/status
  • A LOT of other stuff.. check it out!
Replay infoThis theme works with Replay for 75c devices. BUT you need to have the International Edition of EScribe 2.0 SP15.1 or later. Your 75c needs to have the right firmware as well (at least 1.1 SP33.2 -  that one works for me), once you update ESscribe and connect your device it should prompt you to update firmware. You also MUST enable Replay in your EScribe profile for it to work.
Using replay: once the above has been completed, load this theme and switch to a replay-enabled profile. There should be a "NO REPLAY" button seen on the main screen. This means there aren't yet any puffs to save. So take a few puffs, until you find one you like. Then the button should change to "SAVE," and you can click that to save that latest puff. Once Saved, the button changes to "PLAYING." Click that if you want to end Replay.
If you are having trouble, check the Replay menu because it gives you more info: Replay Available (if theme/coil supports Replay [read-only]), Replay Ready (Replay is ready to be activated [read-only]), and Replay Active (you can toggle this switch to save your last puff and activate Replay).  You also cannot use a plain kanthal coil for Replay. You can use any temp sensing wire, including combinations (e.g. SS wrapped with kanthal).
If anyone is using the theme and has suggestions, improvements, bugs, or anything else, please reach out in the comments below and/or leave a review. Thanks!
Here are the available color options (blue being the original). Let me know if you have requests for others!:
What's New in Version v2.1.2   See changelog
Changelog v2.1.2:
  • Added a ONE WATT version for those who want one-watt increments on the main screen. Wasn't sure if you all also wanted one degree increments on the temp, but that didn't seem useful so I kept that at 5. Note the it's currently only the blue theme that has the one watt version, but if you have requests for other colors, let me know.
Changelog v2.1.1:
  • Added Pride color scheme upon request
Changelog v2.1:
  • Updated battery icons to more easily tell capacity
  • Updated Replay icons so they are colorless (works for any background color), and now it goes > NO REPLAY (not available) > SAVE (ready to save puff) > PLAYING (Replay active)
  • Screens rearranged to be more cohesive and consistent
Changelog v2.0:
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
s3r
Report ·
· Edited by s3r
Share this review
hawk256
Report ·
Thank you!!
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
niandra3
Report ·
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
