What's New in Version 1.3.1 See changelog
(Note: the screenshots show the battery icon is green, but that is only while charging. During normal use they are blue/white (see below). When battery charge is less than 20% they turn red.)
Changelog v1.3.1:
Changelog v1.3:
Minor tweaks and fixes
With version 1.3.1:- Download
