What's New in Version v2.0 BETA   See changelog
Changelog v2.0 BETA:
  • EXPERIMENTAL changes, I'd love feedback to see if you like the direction I am going, or if I should go back to 1.9 (edit- I'm keeping both, and will split them into separate themes)
  • changed main screen to be less cluttered - less info, but more options
  • buttons on main screen can take you to main menu, info menu, coil info, and quick stats page (that has the info that used to be on the main screen like current and resistance)
    • I don't know about you, but I don't need to constantly see my resistance and battery voltage, so I moved that stuff off the main screen, but it's just a click away
  • moved menu stuff to the bottom, so battery percent could be up top (upon request :))
  • changed Coil Info page a bit with more info
  • fixed the rest of the icons that weren't pixel perfect (removed anti-aliasing where possible)
  • added stealth level gauge to Display screen
  • moved F/C units to Display screen
  • other minor fixes
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
  • Like 7
  • Thanks 4
Levtos
· Edited by Levtos
Looks great and simple.
Thanks
hawk256
Thank you!!
Frank65
Congrats !
RMoniz
Canucklehead
Glad you like it, thanks!
myk376
Inferos
Great and simple 😎
Deen
Logan
benjy337
Thanks very much.
Miamirican
LOVE IT THANKS
Amon
Tortuga
CoxyofNewp
s3r
· Edited by s3r
weirdbeard
Levis1072
Thanks for this theme
Ronbon172
niandra3
Mastervaper
  • Confused 1
maxbarrett
· Edited by maxbarrett
HarleyBill
feulipe
