Replay info: This theme works with Replay for 75c devices (250c devices work with Replay by default). BUT you need to have the International Edition of EScribe 2.0 SP15.1 or later. Your 75c needs to have the right firmware as well (at least 1.1 SP33.2 -  that one works for me), once you update ESscribe and connect your device it should prompt you to update firmware. You also MUST enable Replay in your EScribe profile for it to work.
What's New in Version 1.4   See changelog
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
  • Like 7
  • Thanks 4
Levtos
· Edited by Levtos
Looks great and simple.
Thanks
hawk256
Thank you!!
Frank65
Congrats !
RMoniz
Canucklehead
Glad you like it, thanks!
myk376
Inferos
Great and simple 😎
Deen
Logan
benjy337
Thanks very much.
Miamirican
LOVE IT THANKS
Amon
Tortuga
CoxyofNewp
s3r
· Edited by s3r
weirdbeard
Levis1072
Thanks for this theme
Ronbon172
niandra3
Mastervaper
  • Confused 1
maxbarrett
· Edited by maxbarrett
HarleyBill
feulipe
