What's New in Version v1.9 See changelog
Changelog v1.9:
- fixed About screen thanks to @s3r
- other minor stuff (there's now a Creative Commons license on the credits page.. if you want to use it for commercial use, just reach out to me)
Changelog v1.8:
- changed text color scheme slightly for readability (no more orange)
- changed selection highlighting for for better visibility
- rearranged main screen a bit (battery percent and resistance are now larger and above voltage and current, since they are generally more useful)
- fixed battery icon not turning red when charge was low
- adjusted back button AGAIN to make it more visible when selected
- changed battery icons to switch to red at 25% instead of 20% (keep your batteries healthy long term- charge them before they get too low!)
- updated toggle switches and sliders so they are move visible when selected
- adjusted Replay button on main screen to be more visible/easier to use, and I think it just looks better
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
FINALLY fixed the reset issue. Stats on "Current Stats" screen can be reset, and stats on "Total stats" screen cannot. This is by Evolv's design, it's not up to me. This one's for Ronbon172!!! Thanks for your patience
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
- Minor tweaks and fixes
With version v1.9:
- Download
