What's New in Version v2.1.1 See changelog
Changelog v2.1.1:
- Added Pride color scheme upon request
Changelog v2.1:
- Updated battery icons to more easily tell capacity
- Updated Replay icons so they are colorless (works for any background color), and now it goes > NO REPLAY (not available) > SAVE (ready to save puff) > PLAYING (Replay active)
- Updated battery icons to show if you are charging or low battery (<25% = red, lightning bolt icon during charging)
- Display page split into Display Settings and Main Screen Config pages
- Puff counter is visible on main screen when in wattage mode (this can be hidden in Main Screen Config page)
- Screens rearranged to be more cohesive and consistent
- Items moved away from very edge of screen when possible to improve visibility
- Added Mod Info screen that shows info specific to the device (battery pack volt, atty volt and current, mod/ambient temp)
Battery percent no longer changes color (so it fits in with other wallpapers, e.g. red or green)
- the battery icon changes for charging or low battery
- Added more colors (see screenshots or download page)
Changelog v2.0:
- The theme is now called "Clean Colors" and offers many different color options
- Also made a bunch of visual and usability improvements
- Just added "Abstract Blue and Green" color option (which is technically v2.1, or more like v2.0.5.. more improvements to come for the actual v2.1)
Changelog v1.9:
- fixed About screen thanks to @s3r
- other minor stuff (there's now a Creative Commons license on the credits page.. if you want to use it for commercial use, just reach out to me)
Changelog v1.8:
- changed text color scheme slightly for readability (no more orange)
- changed selection highlighting for for better visibility
- rearranged main screen a bit (battery percent and resistance are now larger and above voltage and current, since they are generally more useful)
- fixed battery icon not turning red when charge was low
- adjusted back button AGAIN to make it more visible when selected
- changed battery icons to switch to red at 25% instead of 20% (keep your batteries healthy long term- charge them before they get too low!)
- updated toggle switches and sliders so they are move visible when selected
- adjusted Replay button on main screen to be more visible/easier to use, and I think it just looks better
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
FINALLY fixed the reset issue. Stats on "Current Stats" screen can be reset, and stats on "Total stats" screen cannot. This is by Evolv's design, it's not up to me. This one's for Ronbon172!!! Thanks for your patience
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
- Minor tweaks and fixes
With version v2.1.1:- Download
