   (21 reviews)
What's New in Version v2.0 BETA   See changelog
Changelog v2.0 BETA:
  • EXPERIMENTAL changes, I'd love feedback to see if you like the direction I am going, or if I should go back to 1.9 (both are still available)
  • changed main screen to be less cluttered - less info, but more options
  • buttons on main screen can take you to main menu, info menu, coil info, and quick stats page (that has the info that used to be on the main screen like current and resistance)
    • I don't know about you, but I don't need to constantly see my resistance and battery voltage, so I moved that stuff off the main screen, but it's just a click away
  • moved menu stuff to the bottom, so battery percent could be up top (upon request :))
  • changed Coil Info page a bit with more info
  • fixed the rest of the icons that weren't pixel perfect (removed anti-aliasing where possible)
  • added stealth level gauge to Display screen
  • moved F/C units to Display screen
  • other minor fixes
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
hawk256
Report ·
Thank you!!
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
Inferos
Report ·
Great and simple 😎
Share this review
Deen
Report ·
Share this review
Logan
Report ·
Share this review
benjy337
Report ·
Thanks very much.
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
s3r
Report ·
· Edited by s3r
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
niandra3
Report ·
Share this review
Mastervaper
Report ·
  • Confused 1
Share this review
maxbarrett
Report ·
· Edited by maxbarrett
Share this review
HarleyBill
Report ·
Share this review
feulipe
Report ·
Share this review
