   (21 reviews)
What's New in Version 1.5   See changelog
Changelog v1.5:
FINALLY fixed the reset issue. Stats on "Current Stats" screen can be reset, and stats on "Total stats" screen cannot. This is by Evolv's design, it's not up to me. This one's for Ronbon172!!! Thanks for your patience :thumb:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
hawk256
Report ·
Thank you!!
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
Inferos
Report ·
Great and simple 😎
Share this review
Deen
Report ·
Share this review
Logan
Report ·
Share this review
benjy337
Report ·
Thanks very much.
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
s3r
Report ·
· Edited by s3r
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
niandra3
Report ·
Share this review
Mastervaper
Report ·
  • Confused 1
Share this review
maxbarrett
Report ·
· Edited by maxbarrett
Share this review
HarleyBill
Report ·
Share this review
feulipe
Report ·
Share this review
