   (21 reviews)
What's New in Version 1.3.1   See changelog
(Note: the screenshots show the battery icon is green, but that is only while charging. During normal use they are blue/white (see below). When battery charge is less than 20% they turn red.)
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
hawk256
Report ·
Thank you!!
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
Inferos
Report ·
Great and simple 😎
Share this review
Deen
Report ·
Share this review
Logan
Report ·
Share this review
benjy337
Report ·
Thanks very much.
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
s3r
Report ·
· Edited by s3r
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
niandra3
Report ·
Share this review
Mastervaper
Report ·
  • Confused 1
Share this review
maxbarrett
Report ·
· Edited by maxbarrett
Share this review
HarleyBill
Report ·
Share this review
feulipe
Report ·
Share this review
