Clean Colors (75C/100C/250C w/Replay - Many colors available) v2.4
   (23 reviews)
What's New in Version v2.4   See changelog
Changelog v2.4.1:
  • Fixed ONE WATT versions.. they were not doing one watt increments in replay mode. That's fixed now.
Changelog v2.4:
  • Fixed LED indicator: blue when firing, red while charging, green when full battery (with a pulsing effect)
  • Added option to change date format on main screen (either MM/DD or DD/MM, see Time Config menu)
Changelog v2.3:
  • Fixed main screen:
    • temp changes to voltage when in watt mode
    • small voltage changes to puff count when in watt mode (so voltage isn't displayed twice)
  • other minor tweaks/fixes
Changelog v2.2:
  • Fixed some items on the main screen what weren't positioned perfectly
  • Changed highlight/selection colors slightly for better readability
  • Added new ONE WATT version colors: now available in Blue, Green, Black, and Red
Changelog v2.1.2:
  • Added a ONE WATT version for those who want one-watt increments on the main screen. Wasn't sure if you all also wanted one degree increments on the temp, but that didn't seem useful so I kept that at 5. Note the it's currently only the blue theme that has the one watt version, but if you have requests for other colors, let me know.
Changelog v2.1.1:
  • Added Pride color scheme upon request
Changelog v2.1:
  • Updated battery icons to more easily tell capacity
  • Updated Replay icons so they are colorless (works for any background color), and now it goes > NO REPLAY (not available) > SAVE (ready to save puff) > PLAYING (Replay active)
  • Screens rearranged to be more cohesive and consistent
Changelog v2.0:
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
  • Like 7
  • Thanks 4
Levtos
· Edited by Levtos
Looks great and simple.
Thanks
hawk256
Thank you!!
Frank65
Congrats !
RMoniz
Canucklehead
Glad you like it, thanks!
myk376
Deen
Logan
benjy337
Thanks very much.
Amon
Tortuga
CoxyofNewp
s3r
· Edited by s3r
weirdbeard
Ronbon172
niandra3
Mastervaper
  • Confused 1
maxbarrett
· Edited by maxbarrett
HarleyBill
Clean-Color-Blue-2_4_HARLEY.ecigthemeFetching info...
feulipe
