Cynthia just posted something in the DNA group on facebook about how evolv is coming out with more than one new board at the end of this year....so I'm assuming she already knows.  I think it's coming guys.
I avoid facebook etc as they are just a undecipherable and often unfriendly stream of wtf to me (dyslexic), w = why not what mostly.  But if they are making the world better more power to them, and from your post I get the feeling Cynthia & Co are.
  • Like 2
I'm seriously praying for usb type-c and 3a charging. This is could be a huge board for new vapor and experienced vapors alike, but it's basically 2018 and type-c is the new standard. Pc, Mac, and Android devices either have or are working to adopt this. Micro usb is quickly going the way of the old mini usb.
Good point, make it an actual setting. Plus bi-directional power, and up to 20a charge for the big lipo batts. It should probably give you a choice within a range based on your wh from testing your battery setup, or be locked at 3-5a until you run the test
2 minutes ago, dylang919 said:
I thought the 75c uses the new usb C.  If so, then this new board definitely will.  Evolv should have pulled out all the stops on this one. This should reign supreme for a while.
75c uses micro usb. But type-c has been on the 550j for like a year now
1 minute ago, Zaptear said:
I don’t use onboard I still pull my lipo out and charge with a lipo charged my self but I don’t use any mod to charge my cells anyhow
Ahh... why not do the same with your iPhone? :)
Not saying it’s bad to use the board i use lipo unraglated as well it’s just something I have been doing from when I started vaping
but seeing u need that ubs jacks to last for updates and for profliles my choice is not to over use the ubs Jack is all
Edited by Zaptear
If the device and board is well-made (not some cheap Chinese shit), and has at lest 2A charging option - why not charge it? We use phone's usb/lightning jacks every day, and nothing happens.
And I have no idea why do vapers think that $20 - $30 LitoKala or Nitecore won't die while charging 4 batteries, but $100+ device with 2-3 batteries won't handle charging.
I'd prefer to have a USB C on DNA board and possibility for 3-5A charging. That will allow me to change batteries in my device only 2-3 times per year, when I buy new ones... :)
We might see the USB-C, but I doubt anything over 2 Amps.  Look at the 75c, Evolv gave it 9 volts but only 1 amp charging.  Never heard the reason behind that.
MARKETING TRICKS: 2A will be upgrade that makes you buy 75C.v.2 board :)
Edited by iAlexander
Tried joining the Facebook page and been waiting two month for approval from Cynthia. Looks like she dropped the ball and went AWOL.
Just great....
