CMK
Everything posted by CMK
  1. It was just a train of thought because you wrote that the mod "stands overnight ..." and "... in the morning ...". I don't have any other ideas either, the professionals may have to deal with that.
  2. I have one question - do you charge the batteries externally, or in the mod? My thinking goes in the direction that the display might (!) be damaged by overheating. When charging 2 cells in the mod, the board heats up to almost 60 ° C at a maximum charging current of 2 amps. With 3 cells it should be a few more degrees. The chips are approved for higher temperatures, but I don't know how the display will work.
  3. Thank you first of all. I certainly offer themes that completely require the chipset - and yet I have already installed a switch there that reduces the range of functions. I just think that many users buy mods with a DNA chip primarily because of the replay function. Then because of the mods themselves, a certain exclusivity also plays a role. I guess I'll actually add a screen to the theme; I will outsource boost / preheat and bring back the chart display for it.
  4. I wonder which functions that are relevant to vaping are missing that make up the DNA chip. Please do not get me wrong - I would like criticism that will help me. But here I am missing the substance. In addition to the TC mode with complete preheat control, the theme naturally also offers the power mode with replay. In addition to the usual functions, incorrect settings are expressly pointed out in the theme after a material change, or such settings are excluded. Clear warnings when the battery level is too low and when the board is about to overheat. All things that no other chipset can offer and are hardly implemented in THIS form by other authors. You just can't see it on the screenshots; you have to use the ThemeDesigner for this. What is missing, however, is the comfort equipment, the statistical and diagnostic functions and there are hundreds of other themes.
  5. 16/07: I like the theme very much - for two simple reasons: A nicely reduced lockscreen and no "experiments" in the settings of the mod. Both of these are very important things for me, as the screens are often hopelessly overloaded (I also did earlier ...) and on the other hand, settings of the mod are often enabled, which often lead to problems in daily operation - not only for beginners. 07/17: Unfortunately, I have to massively correct my rating downwards, as I have now seen the stored system notifications and such a (partly wrong) sh ... does not belong published. If these are corrected, I will also increase my rating again
  6. Somehow you don't seem to understand the theme, but count the number of screens ... The theme offers everything that the DNA chip offers - except for the date and time. For whom it is important to analyze your puffs directly on the mod, to regard the DNA chip as a milestone to Mars: there are a few hundred other themes ...
  7. 509 downloads
    - deutsch und englisch umschaltbar in einer Bedienoberfläche - too many details to list them; You will discover them in daily use and you will love them ... Description_for _translation.txt See also my other Themes:
  8. As I wrote - Dovpo will provide me with an Odin 75c and then I'll comment on it. (let's see how long it will take him to be with me)
  9. My English is not that good, but as far as I understand it is still not limited whether it is a problem with the 75C or a problem with the mod. The comparison was again made with an Odin 75c. So I find it a bit presumptuous to discuss problems with mods in an Evolv forum, since Evolv does not make mods. A mod is the sum of its parts and the chipset is only part of it (albeit a very important one, of course). In the foreseeable future I will be provided with an Odin 75c and will then comment on it at a suitable point.
  10. If there are problems "with the 75C", problems in operation, false expectations or even faulty hardware can not be ruled out. Apart from my own consistently positive experiences, I have not heard of any comparably bad testimonials.
  11. Maybe there is a way to use another mod with a 75c chipset for comparison? I cannot understand this bad rating and just want to rule out that it is not a faulty mod or a faulty board.
  12. Hi, I can only share my own experience, but cannot make a well-founded, helpful explanation. In addition to my various LostVape mods with 75C and 250C chipsets, I also have two Aspire-MIXX. I also operate the latter exclusively in the MTL range, also in the watt range below 20W mentioned. I can confirm the observation that the same vaporizers / coils on my DNA mods require about 10% more power. But we only know what we see or what the mods show us. So I assume that in this comparison Aspire / Evolv is the reason for the control of the chipsets. Both tell us that they WILL fire at 18W, for example - what they actually do afterwards is another matter. At least Evolv lets us evaluate this; even on the mod with a corresponding theme. What Aspire ACTUALLY DONE; we do not know it. The difference between mods from different manufacturers with comparable chipsets becomes more interesting. So Odin 75C vs. Thelema (250C). I just switched back and forth in the 18W range between 75C and 250C - but both mods from LostVape. I cannot determine any differences in the watt range, in the TC range I've had the feeling for a long time that the 75C is a bit more sensitive here. Both require the same power for the same target temperature. The difference seems to actually lie with the two manufacturers Dovpo versus LostVape. I can only explain this to myself with the different electrical properties or the values stored for them. Hi, ich kann nur meine eigene Erfahrung teilen, jedoch keine fundierte, hilfreiche Erklärung abgeben. Auch ich besitze neben meinen diversen LostVape-Mods mit 75C- und 250C-Chipsätzen auch zwei Aspire-MIXX. letztere betreibe ich auch ausschließlich im MTL-Bereich, ebenfalls im genannten Wattbereich unter 20W. Ich kann die Beobachtung bestätigen, dass die gleichen Verdampfer/Coils auf meinen DNA-Mods etwa 10% mehr Leistung benötigen. Wir wissen aber nur, was wir sehen, bzw die Mods uns anzeigen. Von daher gehe ich davon aus, dass in diesem Vergleich Aspire/Evolv die Ursache in Steuerung der Chipsätze liegt. Beide sagen uns, sie WERDEN mit beispielsweise 18W feuern - was sie dann anschließend tatsächlich machen, steht auf einem anderen Blatt. Zumindest Evolv lässt uns dies auswerten; sogar am Mod mit entsprechendem Theme. Was Aspire tatsächlich GEMACHT HAT; wir wissen es nicht. Interessanter wird der Unterschied zwischen Mods verschiedener Hersteller mit vergleichbaren Chipsätzen. Also Odin 75C vs. Thelema (250C). Da habe ich soeben im 18W-Bereich zwischen 75C und 250C hin und her gewechselt - allerdings beide Mods von LostVape. Ich kann keine Unterschiede im Wattbereich festlegen, im TC-Bereich habe ich schon lange das Gefühl, der 75C ist hier etwas feinfühliger. Beide benötigen für die gleiche Zieltemperatur die gleiche Leistung. Der Untrschied scheint also tatsächlich bei den beiden Herstellern Dovpo versus LostVape zu liegen. Ich kann mir dies nur mit den unterschiedlichen, elektrischen Eigenschaften, bzw. den hierzu hinterlegten Werten erklären.
  13. Je tiens à souligner que j'évalue la façon dont vous traitez les critiques de manière absolument positive. Beaucoup devraient prendre exemple sur vous.
  14. Après lecture de la description, la seule question qui reste est de savoir ce qui a maintenant été modifié dans la V3 pour que ce soit le thème le plus abouti au moment de la publication.... Peut-être que je suis trop simple d'esprit, mais je ne vois aucun changement dans la navigation qui serait plus facile que dans le thème par défaut. En tant qu'auteur, vous êtes bien sûr enthousiasmé par votre travail - mais vous devez vous en tenir aux faits.
  15. I just downloaded it because the screenshot seemed incorrect ... He is - for whatever reason. It should be noted when evaluating that this is a theme for the 75C! If the wattage is greater than 99.9W, the display will be incorrect. In any case, it's interesting to see stock themes from other manufacturers.
  16. My thought went in the direction of the index - search engines stop - the only thing I couldn't explain was the number.
  17. I think that's a sensible approach, which has already changed the counters of some themes a lot. But is actually consistent - the number of colors, logos, languages, etc. doesn't make a theme better or worse itself. AND there is more real feedback about the interest in the theme, or whether "just" different variants are tried out. Not to mention the collectors ... Everyone loves downloads, but now this was really scary - what kind of bot was that? With my "2 in 1" that was ~ 1500 downloads in a very short time! Great suggestion
  18. 179 downloads
    Even if the theme looks like a pimped out stock theme at first glance, the actual operation has been completely revised and equipped with extensive functions to prevent incorrect operation. Furthermore, the entire boost / preheat control is also carried out on the main screen - only the control elements are displayed that are also switched on and off from there. The navigation is very intuitive and fast. Description_for _translation.txt You might also like the Portrait version:
  19. I would like to note that it is not a fault, it's intended that the graphic batterygauge signals "full" at a battery level of around 85%. The remaining 15% to 100 are only shown in the numeric display. I decided to do this because I consider the range between 80 and 100% insignificant in practice and this form of representation benefits the design.
  20. 640 downloads
    Even if the theme looks like a pimped out stock theme at first glance, the actual operation has been completely revised and equipped with extensive functions to prevent incorrect operation. Description_for _translation.txt You might also like the Portrait version:
  21. "Was gibt es neues in der Version 1.2 Add an 2nd Author (gwyar)" => That's too much - I only gave a few tips, the idea and design come entirely from Lupatio! A promising first work 😎 - I like the graphics, the interaction between the display and the background.
  22. In all of my own custom themes I have a screen in which I have the integrated diagnosis and the power / temperature setting together. I find this very practical as I also prefer TC when the coil allows it.
  23. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/
  24. Here in the forum I am constantly working either with the Google translator or with the translation function integrated in Chrome ... This is how the other users translate what I write, or even Zark's contributions - and they are written in Cyrillic!
