Frank65
Everything posted by Frank65
  1. Looks like both theme and autolock are working correctly now . 👍
  2. @stephanedegee hello did you try to upload experimental software James posted above ? That solved for me the autolock bug For the missing profile , check in escribe "Hide this profile" box in unchecked Regards
  3. Hello Yes TC is working correctly. Also Temperature is showed correctly if no condition is used , I've tested this in some themes with same results . Probably the problem would replicate in another fields with complex showing\hiding conditions. have a nice weekend !
  4. Dear James Thanks for your effort. First test on your experimental firmware seems to solve the problem , before autolocked was engaged randomly after 1-10 minutes , now after one hour mod it's still unlocked ->good ! You say "it may have other bugs" , yes you're right now some fields on theme are not visible anymore (example : atomizer temperature on main screen , reverting to last stable fw it's visible again) .-> please check This after around an hour of testing. Thanks and Regards !
  5. Hello , same problem of forced auto locking here on a Sentinel dna60c. Ecig attached. Thanks for you attention 00041.ecig
    Great theme as always 😀
  6. @abeirokid Hello and thanks , I try to answer your questions : - sleep mode : cannot replicate problem , if i set on device to 1 min , after 1 min my mod goes locked - click to lock : it is working when you lock ( if I change to 3 it locks after 3 clicks ) , to change unlock you should change "set unlock sequence" on settings menu on the mod. Personally i moved these parameters only one time because I like 3 clicks to lock\unlock instead of 5 , and never touched them since then and they're working , so sorry cannot help. maybe you accidently changed unlock sequence ? Please check that with escribe. regards
  7. Version 1.0.0
    1,577 downloads
    Jac Vapour theme for DNA75
  8. hello Unfortunately what you're asking it's not possible as far as I know 😕
    Something original , I like this.
  9. Added ! Hope you like it Very nice box you lucky man 😁
  10. Easy way : from Theme Designer , under first label Appearance , set Wallpaper to None.
  11. Yes I think that's a theme error , I'm going to fix it next release (hopefully soon).
  12. Hello , open the theme with theme editor , on top right see button SPACE USED , that is showing you % of board memory used. Filesize doesn't matter.
  13. Hello I think that when you fire it the resistance impedance getting higher is very normal . Actually I'm vaping on a ni200 0.25ohm coil in TC and when I fire it jumps to 0.45ohm , locked or not. I'm not a DNA guru , been reading this : https://ziggicig.com/why-does-my-coil-resistance-keep-changing/ 😁 Sorry ,maybe if you ask directly in the forum I'm sure you can get better help !
  14. Yep that's true I can replicate that. That's strange because in the theme the only condition for lock icon to be hidden is temp sensing material is not true and this condition is true if replay is working😲 Anyway , if you remove the above condition , you can lock the coil no matter what , I've attached a modified theme for you , please check and let me know if it works. Regards TEST_LOCK.ecigtheme
  15. Hello I'm not sure to understand 100% , but as far as I know no locking is necessary in replay mode. Said that , you see no lock icon with that coil because the firmware doesn't recognize it as a temperature sensing material. Try with a simple TC wire and then you will be able to lock it. The lock icon in the theme is hidden if "coil temp sensing material" is "untrue" . I think this problem is firmware related , not theme. Take a look at this thread , there is a patch you can try (at your risk ):
  16. Hello To lock the resistance : from the main menu select the ohm values and click , you go in the coil menu (see below) , where you can lock the coil You cannot do that directly from the theme , but from theme designer : open the theme with theme designer -> Appareance menu -> Fading -> Active time (modify this field as you wish and save\upload theme to your mod) @FrankV
  17. Yep you're right , on Escribe you can choose punch OR temp , I will check for a solution on new theme revision. Thanks for finding this bug !
  18. Hello Yes that's correct , it was wrong in previous versions , now it should work as expected.
