Frank65
Everything posted by Frank65
  1. Hello Probably your coil is not replay compatible , what material are you using ? Does the screen shows Save icon ?
  2. Hello They're talking about this in this topic. James from Evolve says : My opinion is that replay is working in TC , and it records the last TC puff trying to replay it. Don't know if this answer your question , but yes I would use replay AND TC with Titanium coil 🙄
  3. Hi If you want send me your theme and i'll check it
  4. Hello I mean the dimension you can see by selecting on theme editor your object\picture , clicking ACTIONS button on the right , then RESIZE.
  5. No they don't have the same size , otherwise you should not see that message. Double check 🙄
  6. Hello Loxias Happy you like my theme. Maybe the DNA firmware (the theme is just aesthetic , you cannot decide data refresh time or modify the logic) has a lower refresh of Device Monitor. So I think the lag on preheat indication is not something you can modify and it's common to all themes. Maybe you can try a simpler theme and see if it reacts faster... ?
  7. Did you install Escribe ? See here : https://www.evolvapor.com/products/dna250color and here
  8. Hello @CK1 , you have to (I assume you're using windows o.s. ) : Connect your device to a pc via usb cable Locate on pc where the file is (file extension is .ecigtheme ) Double click on this file , a small window opens On this window click button "Yes, Install" Wait until the file is uploaded Enjoy 😀
  9. Yes you can , and as far as I know there is no risk in using users made 75c themes on 250c (except maybe some lack of functions). You can always revert to default theme. Enjoy your new device 🙂
  10. There are many excellent themes , pick up some and try 😀
  11. Yes you can : (from Escribe) Theme -> Save Theme
  12. Hello It is related on how the cursor moves in the theme screen. I mean , with automatic , the cursor starts from the upper left objects and ends to the down right one. You can set it to manual and assign a numerical tab index to each object , if you need a different functionality. Hope this helps.
  13. @sakuThis is the theme you uploaded corrected. Adding replay is a longer effort ... good luck temp.ecigtheme
  14. That means you have two controls under same conditions with different sizes. You have to check and resize them.
  15. Hello I had connection problems only when using bad usb cables , changing those solved my problem.
  16. Hello and thanks for the feedback. The difference between the old and new version on replay function are only aesthetic , I mean I just replaced a picture with another one. The condition (which turn the ready pic on) "Coil can replay" is the same , and it comes from firmware not from my (or any theme). I doubled checked this So sorry I cannot help .... don't use kanthal on replay ps : tonight I will try to put on a ka1 coil and see what's happen ...
  17. Hello In 2.8.4 I added two new themes for DNA250C , only in those themes wattage increments are 5W (I assumed that fits better a 250W mod). Also these themes have powerbank menu available. All other themes are still 0.5 watts increment like before.
  18. Hi,there's a control in Theme Editor which shows last puff time in seconds: Recordings->puffs->time
  19. right click on wattage , click "select other control" until you reach the temperature one. I know it's tricky and unfriendly , but that's how the theme editor works
    I do like this theme , very clean and stylish interface and great visibility. Congrats !
