VapingBad
VapingBad last won the day on October 28 2025
VapingBad had the most liked content!
2 Followers
VapingBad's Achievements
Senior Member
Senior Member (3/3)
148
  1. ECig['USB Current'] = 0.0 for boards that have an inbuilt charger
  2. Don't forget the atty, so many have a centre pin that screws in which after lots of heat-cool cycles loosens and lets in dirt, try loosening a tiny bit then tightening all threads in your atty that are part of the current path.
  3. Res should never drop when you fire, either fitted the atty hot or have a connection or coil issue. I will repeat what I have posted elsewhere: I get this with a clone Exocet in a clone BB, I override and lock the res to the min, then adjust the res value to tune in the vape, too hot lower the res, too cool raise the res, with SS these adjustments are only 0.01 - 0.002 ohm at a time. The board can't cure an atty with a inherent unstable connection issue, but you can probably use this method to work around it.
  4. 200 & 250 a little longer for the battery balance connector, maybe 5 or 6 mm, just extending the length at the bottom of the board. The button and screen cut outs and mount hole spacing are all the same the same.
  5. Try those, they will be almost identical as these are per cell, up to 4.2 V regardless of the number of cells.
  6. Theme designer add field - setting usb current (sort of charge current, but at 5 v for USB) maybe Theme designer add field - device monitor field Battery current (would include charge, not tried) Theme designer add field - device monitor field Atomizer current (amps while firing)
  7. Not got one, but looks like those tabs are the screen holder, try removing the 3 hex screws holding the board down I suspect it will lift easily after that and you will be able to change the screen easily. ETA You can see the lower screw in the bottom left of the photo, the other two are in the top corners of the board.
  8. Ni80 is not a temp control wire, just vape that in watts/power mode.
  9. From a brit POV StealthVape are tip top, no safer hands.
  10. Yes and yes, the boost is in the latest international firmware and only for the initial art of the puff.
  11. Almost certainly a connection issue, could be the way the mesh is connected in the atty and you may not be able to change the. After vaping TC since the DNA 40 I had to use ohm lock for the second time, both times were with clone atties, the first was an Origenny 2 ( managed to fix that by stripping some of the anodising) and now with an Exocet (for Billet Box). It feels a bit like defeat doing it, but it works tuning by taste. In Atomiser Analyser override ohms to the lowest it registers in Device Monitor, set the temp to your norm, if to weak increase the res a little, if to lively lower the res a little, repeat until it hits the sweet spot. Only do this if you have to, DNAs do a great job with good connections and like I said I have only had to do it twice since TC hit the world. Some gnarly coils may benefit even with good connections they can jump about in res terms.
  12. Worth checking the centre pin on the Armoanizer they work lose over time.
  13. It fits connection issues, I'm not absolutely saying that is it, but it fits, clean threads and surfaces (including 510 centre Pin both sides, battery contacts etc), atty centre pin or joints between more complex atties body sections also can cause issues. Any brass or copper in the chain can oxidise and accumulate general dirt over time and needs regular maintenance, not every day, week or month, just keep an eye one it.
  14. See the data sheet found here https://www.evolvapor.com/products/dna75 page 6 will help you to change to a power profile.
  15. Or try a different browser
