I see a lot of folks wanting to use EScribe with a Mac but I don't think I have ever seen anyone mention for example running Win XP on a Mac with boot camp. There are some really small instanances of XP out there. Just saying
Would you mind checking your setting for mod resistance in EScribe under the mod tab and post it here? If for some reason it's way off that might be the problem. Generally that setting will be 0 to 0.006 ohms.
Battery analyzer will just make your battery bar and battery percentage more accurate. Setting the watt hours correctly is all that you really need to do. You should be able to find the CSV for your battery in this forum or the mod's makers web site. Or you can run the battery analyzer.l
I plan on letting the battery just live in there, if the HD2 fares better it will just stay in there for a long while. I'm not expecting to be noticing any difference but we'll see.
So to get in on the act I took my HE4 in my SMY SDNA75 down to 3.3, that's when I got to see the battery bar flashing for the first time. Using @ 40 watts/50 preheat.
Hcigar and Hotcig come to mind. There was a group buy early on for the Hotcig and they were told up front there would be no manufacturer's warranty. As I recall they did end up warranting them though as there were a bunch with bad batteries.
Have a set of rods, drill bits, Allen keys ect. of known sizes or get out the calipers and size the rods. But you don't need to put in that info to get TCR/TFR as that doesn't change with size or ohms, it only changes with different material
I didn't try to fire it with only the balance connector on but as I posted earlier pack voltage was there but the cell voltages while adding up to the pack were unbalanced. Checked with a meter though they were balanced. I'll try again when I actually get up.
First off the voltage being displayed in device monitor is what you need look at as what is on the display may not be accurate. Is the situation with needing jump started with the usb even after charging stops?
