Everything posted by retird
retird replied to David Campbell's topic in EScribe, Software and Firmware
Go back to the previous firmware and see if the spitting goes away...if not look for something else, maybe rda related... -
Ditto Mike... PIF or trash....
http://www.protovapor.com/product/evolv-510-connector/
If you think it is the 2016-02-29 firmware you can install a previous firmware versiuon and see if that fixes it
THANKS.... I was expecting a flashing message when the fire button is released too... the "Show Temperature" changes the wattage displayed to Temperature and goes away when the fire button is released,,... thanks again....
So there is no shown "message" for that setting? There are three choices for that theme. Don't Show, Show Temperature, and Show Message. When Show message is selected it flashes Temperature Protected when Temp is reached, when Don't Show is selected it doesn't flash a message even tho temp is reached. When selecting Show Temperature it flashes no message either even tho temp is reached. So what is the purpose and function of the Show Temperature setting? I'm just trying to figure out if some message is supposed to flash and show something. If not then that setting does the same thing as the Don't Show setting. If it is supposed to flash a message I don't see one thus it may need to be identified as a bug than can easily be fixed.
OK, I was just fiddling around with themes and ran across this. Go to Themes. Go to theme, Custom Screens, Temperature Protected Set it to âShow Temperatureâ Upload it and when temp is reached while firing it doesnât show any message forâ temperatureâ as it does when setting it to âShow Messageâ it shows âTemperature Protectionâ message. What step am I missing here. Tried on several DNA200's.
How about just contacting Evolv using the "contact" Submit a Ticket and let them guide you? Here is the link.... http://helpdesk.evolvapor.com/index.php?a=add
Only a thought..... were you using the same atty on each device when they failed? I have one atty that worked fine on many mods but not on one particular mod.
Two guesses.... maybe e-liquid on the boards or maybe intermittent contact in the fire buttons. And you might check for a loose ground.
So, Escribe won't open??? Try the restore function in Windows to restore the computer back to a date when it worked without issue. That restore point may help. -
How about going to device manufacturers web site and installing their latest firmware... http://www.wismec.com/product/reuleaux-dna200/ -
Try removing the Nickel200 wire from the device (click on red X below the Material on Device Box). Then add the Nickel200 wire to the device again. -
Works just great with Win-10 here...no lost data.... maybe you are missing something during the update process...when the test update was just out I installed/uninstalled/installed EScribe and the firmware update three separate times on two separate DNA200's without a hitch. -
Have you ran Case Analyzer? My two DNA200's are not doing what yours are doing either. Refinement works just as it always has... no problems here... -
Issues with warranty service and continuous firing.
retird replied to MrFixite's topic in Report a Bug
How about a picture of the wiring? Will help seeing what you have... -
Great.... thanks for the info... at least this discussion allows folks to see this is not an issue to be concerned about...hum.... Microsoft?... that's another story..... Have a great day James (and associates).... -
Updated to the latest test firmware of yesterday. When I downloaded the .exe file my Norton Internet Security said the .exe file was safe. When I clicked on the .exe file to install EScribe I get the following (using Windows 10, 64 bit). I click "Run Anyway" and install EScribe without issue. The firmware update from within EScribe works just fine. All is good but just wanted to post the Windows warning I got each time I ran the .exe file. CLICK on "More info" and you get this screen: Picture from Windows Control Panel shows settings for Windows SmartScreen: ( Control Panel/System and Security/Security and Maintenance/Security/ Windows SmartScreen/Change Settings) Easy to change setting you want to use for unrecognized apps.... -
Reuleaux RX200 by Jaybo & Wismec is a new version of Reuleaux MOD with Joyetech chip board and it doesn't have an Evolv DNA200 board in it. Apples to oranges. RX200 is not a DNA200.
You are very welcome.... glad I could help.... enjoy....
Good you got it done....
So you tried to force the update and got an error message... did you click thru the error message? Try again... In EScribe try clicking Get Information under MY DNA in the General Tab....
That is dated August of last year... you can go to post 1 in this thread to load the latest test version or the recommended version below it......after loading the one you want you might see if it works for you... if not try this: Click on Tools/update firmware... open the dna200 folder... click on the latest file and click open.... forces an update which may help.
So you have latest version from this forum site or Evolv's main website? Click on Help/about EScribe... and see the version number...latest is 1.0.39
So did you uninstall EScribe and re-install it since it crashed? Which version of Escribe?
