Well your mod thermal characteristics are "evolv's" defaults (not set up, or you reset them) Your batteries probably some old ones and heating up under load (50F in the first pic) and is running out of power or hit the soft cell cutoff. AND you're locking your resistance so the board cannot refine the cold ohm value My suggestions: Buy new batteries from the Mooch approved listRun your own 'mod resistance' - 5 minutesRun your own 'thermal characteristics' - 3 hoursDownload 316L profile from Steam Engine, or use the evolv default or Djlsb value of .00092DO NOT LOCK OHMS if your resistance is solid. If they're jumpy, fix your build.Resistance lock: The DNA 75 relies on the cold resistance of the atomizer to measure temperature accurately. If the connection is not stable or if you find the measured resistance drifts with time, it may be desirable to lock the atomizer resistance
Thanks man, I knew I forgot to mention that
Alrighty then, so it looks like your coil needs somewhere around what your 'power' line shows (inverted green 'v') to maintain that temp. If that's sort of YOUR typical coil build, you can lower those maximums to more reasonable values. If you don't want as quick a ramp up, lower your punch slowly till you find your sweet spot. Once you set your 'thermal' calibration, it gets even more consistent
@VapePanther do ya mind 1 last DM print screen for sh17s and giggles If you're getting nic'd out ... rest mod beside you ... bottom right hand corner .... puff for 4 second.
@VapePanther You posted profile 1 which looks good for TC. Your Device Monitor showed you were using Profile 2. Please Device Monitor while firing showing Profile 1
That is your profile 2
Yup, same here
I just did my 250 using the 'giz' method and measured a solid .003 (Atty, coil, and method validated on 2 mods prior)
Doesn't your body/head give you a built in puff limit? A normal cigarette lasted me 8-10 minutes, and after that I was done. Now, with my nicotine level set appropriately, I lose my 'craving' after the same 10 minutes or so. 'Or so' meaning that I no longer have to continually puff because there's no tobacco burning away without being inhaled. If I vape after more than 'that cigarette' my head will start to hurt/buzz/tingle.
Answer here: https://goo.gl/csaLSR
Stolen from 2 of the finest on here: With Device Monitor showing you just hit the "prt sc" button on your computer.Open a Paint software program and click on "Paste".You can change size, orientation, and etc. in the Paint software.Save this to your computer.Attach the saved file to a post here. OR (if you press [ALT]+[PRT SCN], open MSPaint and paste [CTRL]+[V] you have a screen shot from any program, that you can save and upload)
And maybe check that USB charging has not been disabled on the device.
Of my 6 different brands all have been set, including LostVape Efusion Duo, just lucky I guess. (I run my own anyway)
Off Topic: Did ya'll notice the default mod thermal settings also? Are the mfgr's really this lax and not doing this, or is it new users happy with a hard reboot? (I notice there were no resets of the data in his screen shots)
Here's a quality 'smaller' sled 2@18650 that many modders rave about. http://bit.ly/2nitzk5 $4.25. He's even got 20700 sleds (If you didn't have all those 18650's)
".... not something we would warranty, however we do have replacement screens available here on our website." For purchase
Not remotely relevant, but that phantom 3rd cell 'display' was fixed a few updates back in Escribe.
Thanks @LeeWB3. We're all good, I'm just trying to help, and my post was just intended to get my noodle to my starting point. @dwcraig is much more knowledgable than I, but I'll re-read everything again, post coffee, to see if I have any thoughts.
@LeeWB3 You described a large surface are coil that showed it was not even hitting your set temp AT ALL in 6 screen puffs. I only suggested a much higher wattage so we/you could actually see the power required to get there. The speed getting there is a balancing act between the other parameters, and I'm quite sure you've been told that.At no point did I even remotely insinute this: so to be argumentative you then go on to describe a completely different coil I take it you're having a bad day. Relax man.And as you say why not just ask what the fix was.Have a good day, I hope you solve your issues .... whatever they are. My comments are obviously of no value to you, so I won't be reading or replying.
So from all of that and your print screens, neither mod is hitting the temperature you've set.You describe a claptionized coil, which IMHO needs much more than ~30 watts for initial heating. I'd suggest you set both mods to at least 100w and do some print screens at that setting. Couple more things. Let each mod and atty sit for 5-10 minutes before using in TC so we're sure you're using a room temp mod and atty. Also, please include a print screen of your profile setting. You're at least half way there. Edit: if your concern is Mod Calibration, what is the current setting for Mod resistance of each?
Wayneo replied to David Campbell's topic in EScribe, Software and Firmware
@sdmf74 I gotta start by saying I agree with you 1 million %, and have commented/complained about this before myself. This happened BG (before giz) and my old tired brain is full of crap, so lemme explain. And your confusion is well justified, it's not just you. *** 2015-10-21 EScribe 1.0.35.2 *** This was the only software listed that was misplaced by date. *** 2016-08-08 EScribe 1.2 SP3 *** Notice the date on this one, yup, the OLD FDA deeming regulations date where it was a mad rush for every vape related company including Evolv. Really minor bug fixes were found, but with no clarity and uncertainty if software changes are/were allowed, minor tweaks have been added. *** EScribe 1.2 SP4 *** Was the next release and you'll notice there have been NO RELEASE DATES attached to it, or any other updates since. I truly wished they would decouple the update versioning. 1 set of versioned updates for the mods with relevant change documentation. Different versioning for the software with relevant change documentation. Although that is what I wish, not being a ENDS Manufacturer, there may be legalistic reasons for the way it's being done. -
A full print screen. All the information is valuable
Only ever used the 114 octane in my younger days. IIRC it was Purple and a unique clean smell, unburned and at the exhaust. When setting up street races, it could help identify the badass engines. If ya don't wanna blow your face off, limit it via your kanthal max.
I'm just barely a pretty face, and not a builder. I also don't vape that low, but I have a couple thoughts. Could it be a bad solder joint or your battery not making good contact? Is it with one atty or with all atty's? But @Chunky is one of the 'experts' and if I'm out to lunch, just say so. I have the thickest skin and won't be offended. I'll just go back to huffing some C14 in the corner.
Hey, If you only care about quick and dirty, just plug in your battery specs into battery analyzer and it'll give you an answer. If you want accurate results for your battery, run battery analyzer like I suggested.
