Did you follow the datasheet for your wiring? You'd need to use a multimeter at each connection point for each cell to identify what needs to be re-soldered or fixed. Did you solder directly to the board or use the JST connector? Screenshots for future info. The Print Screen button on your keyboard can take a screenshot and save it as a file OR use the 'Snipping Tool' How to Take a Screenshot in Microsoft Windows - https://bit.ly/3bjmx6m
Post a screenshot like below (Device Monitor) same checkboxes ticked, while firing. https://forum.evolvapor.com/topic/71597-change-in-resistance-value-when-heated/?do=findComment&comment=936766
The default Replay profile is usually Profile 1 or 8.
How much is a little? Stabilizes at the higher value, or the lower value? Post a screenshot like above while firing, showing that behavior
Did you dry fire that coil and make sure it glowed properly beforehand ? EDIT: And no. Kanthal should have a steady, non changing resistance.
This is really a hidden gem. 👍Super solid theme! I'd suggest you really take the extra 5 minutes and read the 'about' section so you understand what's going on. Actually, this Author really knows his stuff. Helpful and responsive with others on more than just his many themes. And if you like it, or not, sign up and leave a comment or review. No spam on this site
- 48 comments
- 5
- english + deutsch
- replay
(and 4 more)
Tagged with:
There are several resistances in series that make up the load before it reaches your coil measurement. Every solder and connection point. By properly measuring this 'mod resistance' and setting it, you are then seeing only the measurement of the coil. I guess your other 2 boards were properly done. So now you want all 3 to be the same, but you don't/won't/can't actually measure it on this board. So you can follow that video, or fudge your way to be the same. Follow my last post.
Buddy, we are talking the mod resistance field. The thing you want to change. What is in there right now? Or, sure, you can do that if you want. Here's a video showing how. https://youtu.be/S8f6WtY-f70 Or set it at .006 and work your way up slowly. After changing the setting, always 'upload to mod'.
What numbers are there right now? and why do you want to change it? To answer your question directly, no. It's not difficult, or complicated, but if you don't understand what you're doing then you probably should not. One would normally set the field to zero, then measure, set it to that or a slightly more conservative value.
what wire works best in temp control with dna 75c?
Wayneo replied to leea12345's topic in DNA 75 Color and 100 Color
No worries @SquonkerMoniker, when you said this Some users have not done many of those bolded items. 👍 -
Welcome @SquonkerMoniker 👋 Some users such as yourself are more informed than others. The datasheet for the 75C is here: https://downloads.evolvapor.com/dna75color.pdf The 'fire' button is usually the big one. The 3 in a row, well the top 1 is for moving up. The bottom 1 is for moving down. The middle is the select button. The 'something' can be found using the search field there ↗️ Theme specific questions/comments are usually handled by the creators themselves -
All mods start at zero and work their way up to the set value. Your videos didn't work, but a screen shot in Device Monitor will. Hope that clears it up.
Ummmm, not quite right. #marketing That's just the name of the Mod. I be counting 4, yes four times they name the board/chipset. "featuring the DNA250c chipset with battery configuration of 4×18650 set in series" "all thanks to the Evolve DNA250c chipset that is being used."" "The Evolve DNA250c is a power regulation board created by Evolve" "DNA 250C Chipset" I stand by my initial post. I found your comment extremely rude and somewhat harrassing. Welcome 👋
@Joshua12345 Any news for us? Did you open a support ticket, and what did they say? You gonna post the 'get info' results like @James requested? For clarity of details, here are instructions for screenshots/snips. The Print Screen button on your keyboard can take a screenshot and save it as a file OR use the 'Snipping Tool' How to Take a Screenshot in Microsoft Windows - https://bit.ly/3bjmx6m
No worries my good man. At the bottom of your screen you can go back/forward pages. I'm not one to repeat myself. 👍 If it does, you know what 2 beta testers have suggested you try.
Fresh day so where are we? @Joshua12345 What have you done since yesterday after the same problem occurred again? Are you going to load that .ecig file that @dwcraig1 sent? I'd suggest you do. Thank you @Michael Guercio that's now the 4th time you've said that. You'll just need to wait and see what pans out above.
Need help with error. (Curve must be strictly increasing)
Wayneo replied to nickwa04's topic in Themes and Custom Screens
I don't think it's a theme, but it could be a material curve. So if you look at a material curve, from the far left to the far right must always be increasing. No dips. You can just throw it out. Remove it from any 'profile' then (highlight the material in the right window) and click the left arrow below -
One thing. Did it put back that Boxer theme on your mod?
Here is the default evolv. No boxer logo. No stealth. But you should be able to use it just fine. Connect mod to PC and start escribe. Click "theme" tab. Click load theme. (select this file) I sent, that is now on your PC. Click "upload settings to device" Let me know if you have any issues with my instructions josh default 100C.ecigtheme
Hang tight for a sec there @Joshua12345. I'd like you try the stock/default theme. If you're up to it.
Screenshot yes, exactly like the @dwcraig1 post
Yup, that's what I wanted. Now go back to that post showing the 'Device Monitor' snip from @dwcraig1, and follow his directions on the checkboxes to enable, WHILE FIRING. 👍
Start escribe. Go under "File". Click "Save". Post that .ecig file here. At the top of the screen you should see a message to apply a new service pack, click that, OR Go under "Tools", bottom one is "Apply Service Pack" follow directions.
