Joshua12345 Posted May 10, 2021 Report Posted May 10, 2021 Did you try this @dwcraig1? Restore defaults?
dwcraig1 Posted May 10, 2021 Report Posted May 10, 2021 No but I was running your .ecig file and could not reproduce the problem. 1
Joshua12345 Posted May 10, 2021 Report Posted May 10, 2021 Yeah, I never had a chance to take it off, I hit restore defaults before I ever downloaded the theme you sent, changed the screen to have a hit counter on it, uploaded these settings, and it hasn’t messed up since. If it does mess up again, I will send a post. But otherwise, thank you guys so much for caring enough to help 1
Joshua12345 Posted May 10, 2021 Report Posted May 10, 2021 Still the boxer theme. It’s almost like something had been tweaked on escribe before I ever got the device possibly. Because once restored.. so far it’s working fine. 1
Danny777 Posted May 10, 2021 Report Posted May 10, 2021 (edited) Ginger hard programs the settings and theme directly into the board. So pressing restore defaults did nothing but bring the unit back to just when you received it out if the box. It would correct though any errors you would have made in settings. Edited May 10, 2021 by Danny777 Typo 1
retird Posted May 10, 2021 Report Posted May 10, 2021 3 minutes ago, Danny777 said: Ginger hard programs the settings and theme directly into the board. So pressing restore defaults did nothing but being the unit back to just when you received it out if the box. It would correct though any errors you would have made in settings. Great info to remember....THX 1
Joshua12345 Posted May 10, 2021 Report Posted May 10, 2021 I guess I might have accidentally done something to it either on escribe when I first got it or on the mod itself. Lol maybe this was all self inflicted. Idk but I appreciate you guys
Michael Guercio Posted May 11, 2021 Author Report Posted May 11, 2021 Sorry man... I don't own a computer so I have no way to even try and fix. Hopefully someone can find a solution to this.
dwcraig1 Posted May 11, 2021 Report Posted May 11, 2021 Here is the .ecig file that shipped on my DNA100C Give it a try if you wish, you can always revert it back easily. File/open/choose file/upload to device. Evolv DNA100C stock.ecig 2 1
Michael Guercio Posted May 11, 2021 Author Report Posted May 11, 2021 On 5/5/2021 at 5:31 PM, Wayneo said: When that occurs (battery sag hits the 'cell soft cutoff' value, on your screen (depending on theme) you might see a 'weak battery' warning, letting you know it's soon time to change the battery. Added: What kind of battery are you using? For single battery mods I've always suggested/preferred high Amp batteries over mAh, because of less battery sag while firing. Samsung 30T 21700
Wayneo Posted May 11, 2021 Report Posted May 11, 2021 Fresh day so where are we? @Joshua12345 What have you done since yesterday after the same problem occurred again? Are you going to load that .ecig file that @dwcraig1 sent? I'd suggest you do. 3 hours ago, Michael Guercio said: Samsung 30T 21700 Thank you @Michael Guercio that's now the 4th time you've said that. You'll just need to wait and see what pans out above. 1
Michael Guercio Posted May 11, 2021 Author Report Posted May 11, 2021 2 hours ago, Wayneo said: Fresh day so where are we? @Joshua12345 What have you done since yesterday after the same problem occurred again? Are you going to load that .ecig file that @dwcraig1 sent? I'd suggest you do. Thank you @Michael Guercio that's now the 4th time you've said that. You'll just need to wait and see what pans out above. My bad bro. Im not here often to know how these threads work. I just came across your "what batt" question so wanted to answer the question!!
Joshua12345 Posted May 11, 2021 Report Posted May 11, 2021 Yeah, I’m at work all day. I restored it again, and don’t hit over seventy watts, and the problem doesn’t occur. It’s only if I’m running high wTtage, as well as weak battery on a full charged batt 1
Wayneo Posted May 11, 2021 Report Posted May 11, 2021 44 minutes ago, Michael Guercio said: My bad bro. Im not here often to know how these threads work. I just came across your "what batt" question so wanted to answer the question!! No worries my good man. At the bottom of your screen you can go back/forward pages. I'm not one to repeat myself. 👍 39 minutes ago, Joshua12345 said: ........ I restored it again, and don’t hit over seventy watts, and the problem doesn’t occur. If it does, you know what 2 beta testers have suggested you try. 1 1
dwcraig1 Posted May 11, 2021 Report Posted May 11, 2021 3 hours ago, Joshua12345 said: Yeah, I’m at work all day. I restored it again, and don’t hit over seventy watts, and the problem doesn’t occur. It’s only if I’m running high wTtage, as well as weak battery on a full charged batt With a fully charged battery do this again and hoover your mouse over the area of the lowest voltage drop and post it's value, do this with your Samsung 40T. You should not be getting low battery message firing at 70 watts with a full charged 40T unless your voltage drops below Soft Cell Cutoff and that would be 2.75 volts in most cases. 1
Joshua12345 Posted May 11, 2021 Report Posted May 11, 2021 I’m only getting a low battery message trying to fire at ninety. But the main problem is everytime I hit it and it’s in the black screen, i have it set at 70 and it hits at forty something. But as soon as I fire it again it’s normal
Joshua12345 Posted May 11, 2021 Report Posted May 11, 2021 The weak battery thing isn’t really an issue. I just assume that’s because I’m running it too high. And when it hits at half watts with the screen black, the voltage stays the same. The only thing that changes is the watts 1
Joshua12345 Posted May 11, 2021 Report Posted May 11, 2021 Okay so I’m this picture, I have a fully charged Samsung 40 t. The device is set on 80 watts. During a regular hit, it is hitting at 4.17 volts. Once the screen went black, it appears to be hitting at 46 watts, it also appears the volts went down. But after this, if I keep hitting it.. it still says upper 4 volts
Joshua12345 Posted May 12, 2021 Report Posted May 12, 2021 update: i put the default 100c theme on and it made no difference. it is still doing the wattage drop issue. i honestly think there is something wrong with a connection inside the mod itself 1
dwcraig1 Posted May 12, 2021 Report Posted May 12, 2021 3 hours ago, Joshua12345 said: Okay so I’m this picture, I have a fully charged Samsung 40 t. The device is set on 80 watts. During a regular hit, it is hitting at 4.17 volts. Once the screen went black, it appears to be hitting at 46 watts, it also appears the volts went down. But after this, if I keep hitting it.. it still says upper 4 volts The voltage drop looks to be not the problem. If it was a faulty cell or poor connections between the cell and board it would show in this picture. 2
dwcraig1 Posted May 12, 2021 Report Posted May 12, 2021 2 hours ago, Joshua12345 said: update: i put the default 100c theme on and it made no difference. it is still doing the wattage drop issue. i honestly think there is something wrong with a connection inside the mod itself I don't think it a bad connection as far as wiring, more like the board it's self. This is just my opinion as I am not an Evolv tech. My advice would be to contact Evolv's Help Desk and they will advise you as to how best to proceed. https://helpdesk.evolvapor.com/index.php?a=add&category=1 Add a link to this thread on your contact request. 1 1
dwcraig1 Posted May 12, 2021 Report Posted May 12, 2021 6 hours ago, Joshua12345 said: update: i put the default 100c theme on and it made no difference. it is still doing the wattage drop issue. i honestly think there is something wrong with a connection inside the mod itself Did you change only the theme or did you use my ecig file? 2
