This problem literally only occurs if hitting mod after screen has gone black. It will continue to hit at seventy or right under over and over until the screen turned off, then hitting the button to fire and waking it up at the same time, it will fire at 40 something
Oh, I rechecked the csv file and now see what you say is going on. Didn't scroll down far enough to see it...
Your cold ohm's are showing  0.144 and your live ohm's is showing 0.139, 0.14 to 0.142.  That is not normal.  Cold ohm's are set with the atty and device at room temperature.  Cold ohm's should not be locked...  Fix this first and see if that helps.
1 minute ago, Joshua12345 said:
How do I unlock?
Go to the profile in escribe and see if it is locked and uncheck. You may be able to do in the Theme but have not looked at your theme..
I took a quick look at the .ecig file you gave and none of the profiles is the Power set to 70 watts....  You are using Profile 2  (Watts) right???
Yes, I was using watts profile two, that file I don’t think got a clear recording, because I didn’t know what I was doing. The problem I’m having is clearly going on in the pictures
Here is the default evolv. No boxer logo. No stealth. But you should be able to use it just fine.
Connect mod to PC and start escribe.
Click "theme" tab.
Click load theme. (select this file) I sent, that is now on your PC.
Click "upload settings to device"
Let me know if you have any issues with my instructions
josh default 100C.ecigtheme
ok, so before i try the default theme, i hit restore all the defaults, and now it appears to be working right. i cant get it to fire the wrong low wattage, even when the screen goes blank. im going to keep a watch on it, and finish building the other atomizer i was using that was messing up on it, and see what happens. i really appreciate everyones help and would appreciate if you would continue to get notifications from this thread for the next day or so just to make sure it doesnt start messing up again. i will let you know either way
