nibo Posted February 9, 2019 Report Share Posted February 9, 2019 Hello, I own a new Triade Mod from Lost Vape. I do get the message „error, press up“ after some minutes of not using it and pressing the fire button. I have choosen a standby time via escribe of 15 minutes. So when I put the mod away after vaping and I want to fire again after eg 5 minutes, the message comes up. I have updated the mod too, but still the same issue. Hope somebody can help me. Link to comment Share on other sites More sharing options...
lordmage Posted February 9, 2019 Report Share Posted February 9, 2019 i had to revert to core sp 35 i think to not see the message on my 250c Link to comment Share on other sites More sharing options...
nibo Posted February 17, 2019 Author Report Share Posted February 17, 2019 Hello. Thank you. I do have now permanent "chrashes. No specific reason to find why they happen. I would go back to SP33 (the only older version on my PC under "tools"), but this does not work. I cannot install it. How can I find the SP35 version? I do not know Escribe very good. But this all is not satisfying of course. Is Evolv working on this bug? Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 17, 2019 Report Share Posted February 17, 2019 EScribe 2.0 SP17 includes firmware SP35 https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=928400 Link to comment Share on other sites More sharing options...
nibo Posted February 20, 2019 Author Report Share Posted February 20, 2019 Thank you too. SP 35 does not work for me. Same issue. SP33 does work. No problems so far. Crazy. @Evolv....what is the problem? Link to comment Share on other sites More sharing options...
AnnaR. Posted February 24, 2019 Report Share Posted February 24, 2019 (edited) same at me, SP33 is the last working Firmware for my VTBox250C, it´s sad ;( Edited February 24, 2019 by AnnaR. Link to comment Share on other sites More sharing options...
nibo Posted February 24, 2019 Author Report Share Posted February 24, 2019 Hello. Yes, this is really sad. Premium product. Costs a lot momey. No reaction from an Evolv host in this thread. Link to comment Share on other sites More sharing options...
nibo Posted February 24, 2019 Author Report Share Posted February 24, 2019 I have open a helpdesk ticket now. Hope this will help. Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 24, 2019 Report Share Posted February 24, 2019 I thought that SP38 solved that problem. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=929633 Link to comment Share on other sites More sharing options...
nibo Posted February 24, 2019 Author Report Share Posted February 24, 2019 Unfortunately it did not solve it. Link to comment Share on other sites More sharing options...
lordmage Posted February 24, 2019 Report Share Posted February 24, 2019 (edited) 42 minutes ago, dwcraig1 said: I thought that SP38 solved that problem. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=929633 Edit : this is the most stable for me in terms of the error code have yet to see it Firmware Version: 1.1 SP33.2 INT Edited February 24, 2019 by lordmage Link to comment Share on other sites More sharing options...
AnnaR. Posted February 25, 2019 Report Share Posted February 25, 2019 @dwcraig1: No, don´t works, always "Error Press Up)" after sleep. Factory Reset with original Evolve Theme....same Back to SP33, all fine Link to comment Share on other sites More sharing options...
retird Posted February 25, 2019 Report Share Posted February 25, 2019 Do let us know what Evolv says..... Link to comment Share on other sites More sharing options...
nibo Posted February 25, 2019 Author Report Share Posted February 25, 2019 I will do Link to comment Share on other sites More sharing options...
danielf77@gmail.com Posted March 11, 2019 Report Share Posted March 11, 2019 Hello, Same problem here: Error Press Up Have you got some new information about this bug? Link to comment Share on other sites More sharing options...
postfach.kunz@online.de Posted May 8, 2019 Report Share Posted May 8, 2019 hello, my experience is, I did the update 1_1_SP38_INT and forgot to disconnect by mouse click of escribe, then I had the error message "error press up". I have connected the mod again and with mouse click the device disconnected and it is ok since then. I hope I could help to fixed. Link to comment Share on other sites More sharing options...
nibo Posted July 20, 2019 Author Report Share Posted July 20, 2019 The problem is still not solved. I have reopened the ticket. Wayting for their reply and solution. Link to comment Share on other sites More sharing options...
Wayneo Posted July 21, 2019 Report Share Posted July 21, 2019 @nibo Did you ever try the default evolv theme with SP38? Earlier you said SP33 was working fine. What SP are you running right now, where this is occurring? Link to comment Share on other sites More sharing options...
lordmage Posted July 21, 2019 Report Share Posted July 21, 2019 20 minutes ago, Wayneo said: @nibo Did you ever try the default evolv theme with SP38? Earlier you said SP33 was working fine. What SP are you running right now, where this is occurring? For me sp38 default theme had it. Sp 33 does not Link to comment Share on other sites More sharing options...
nibo Posted July 21, 2019 Author Report Share Posted July 21, 2019 vor 51 Minuten schrieb Wayneo: @nibo Did you ever try the default evolv theme with SP38? Earlier you said SP33 was working fine. What SP are you running right now, where this is occurring? I have mentioned it in Feb. 24th. SP38 did not solve the problem. SP33 does. But thank you. Link to comment Share on other sites More sharing options...
nibo Posted July 22, 2019 Author Report Share Posted July 22, 2019 Now I have a final answer. Not really satisfying, but an explanation. Link to comment Share on other sites More sharing options...
Wayneo Posted July 22, 2019 Report Share Posted July 22, 2019 What's not to like @nibo The soldering to their board needs repairing, and being in the EU, you've been given an EU authorized repair shop. Probably cheaper shipping for you, less customs and duties issues? No? 1 Link to comment Share on other sites More sharing options...
VapingBad Posted July 22, 2019 Report Share Posted July 22, 2019 From a brit POV StealthVape are tip top, no safer hands. Link to comment Share on other sites More sharing options...
nibo Posted July 23, 2019 Author Report Share Posted July 23, 2019 vor 23 Stunden schrieb Wayneo: What's not to like @nibo The soldering to their board needs repairing, and being in the EU, you've been given an EU authorized repair shop. Probably cheaper shipping for you, less customs and duties issues? No? Yes Link to comment Share on other sites More sharing options...
lordmage Posted August 4, 2019 Report Share Posted August 4, 2019 On 7/22/2019 at 3:33 PM, Wayneo said: What's not to like @nibo The soldering to their board needs repairing, and being in the EU, you've been given an EU authorized repair shop. Probably cheaper shipping for you, less customs and duties issues? No? so does @nibopost above mean i should send my device in for repair if sp38 gives me the press up error paranormal 250C i have to sat on sp33 as noted above to not experience it Link to comment Share on other sites More sharing options...
