James Posted August 3, 2018 Report Posted August 3, 2018 6 hours ago, Nabil said: how to activate / use the sleeptest service when I have downloaded it? Go to the Tools menu, Apply Service Pack. 1
Ghoulsfrank Posted August 4, 2018 Report Posted August 4, 2018 Hello, as of today I have never had the deep sleep wake up problem with the patch that's been posted here. Works perfectly. Is it possible that I also have better battery life with this patch installed?
BushBear Posted August 6, 2018 Report Posted August 6, 2018 Hi Guys, i also applied the Service-Pack at Friday and first everything seemed to work o.k. now. No matter, how long it stayed in sleep-mode, after clicking the fire button 5 times, my Paranormal instantly wake up and work as it should. BUT.... after taking batteries out for charging and putting them in again, same problem as before. NO WAKE UP untill i plug in a USB-cable. Then it starts, but all the Settings of Date and Time are lost again. any suggestions??? Thanks for helping!
BushBear Posted August 6, 2018 Report Posted August 6, 2018 lso i can do neither a soft- nor a hard reset/reboot. No problems with my other three dna 250c-devices, but this one really make me nuts. slowly i fear it is a hardware-issue. Please help! Thanks in common!!!
Ghoulsfrank Posted August 7, 2018 Report Posted August 7, 2018 For my Silver Thinkvape Finder 250c who had the deep sleep problems, the sleep test patch has completely fix the problem. Good job evolv
Nabil Posted August 10, 2018 Report Posted August 10, 2018 (edited) after I downloaded the service pack, deep sleep in my 250c paranormal was gone. but the date and time always have to be set again when I wake up from sleep and insert the battery that I have charged all night to my paranormal 250c. how do i overcome the problem of the date and time which always restarts by itself? can anyone help? thanks. Edited August 10, 2018 by Nabil
dwcraig1 Posted August 10, 2018 Report Posted August 10, 2018 I charge all of mine with the batteries in the mod, the built-in charger does a fine job.....just saying.
Jay@ADV Posted August 30, 2018 Report Posted August 30, 2018 Since the update folks i havent had any issue with mine not waking up .
WingedLion Posted August 30, 2018 Report Posted August 30, 2018 Mine started to have the wake up issue today. Had to plug it into my computer to wake it up.
1shootist Posted August 30, 2018 Report Posted August 30, 2018 I'll add my paranormal 250c to the list of those not waking from sleep mode. After reading all the above it appears there is still not a 100% fix..at least with the patch referenced. I'm having to plug the usb in to wake it. If anyone hears of a definite fix please let me know.
Jay@ADV Posted August 30, 2018 Report Posted August 30, 2018 DNA 250 Color v1_1_SP35_US_SleepTest3.sw-service DNA 250 Color v1_1_SP35_INT_SleepTest3.sw-service since i applied this i have had absolutely NO issues
dwcraig1 Posted August 30, 2018 Report Posted August 30, 2018 I had a bit of a time locating these files......until I used "search", here is a link: I guess it was just about right in front of me the whole time. LOL
1shootist Posted August 30, 2018 Report Posted August 30, 2018 Thank you for that. could someone please explain to me how I download it. it says I need something else because its an sw file and its not going any further.
dwcraig1 Posted August 31, 2018 Report Posted August 31, 2018 Firmware resides (by default) here: C/ users/ your name/application data/Evolv/ Escibe suite/firmware/ DNAxxx. You need to put it in the DNA250C folder. An easy way would be to download sw to desktop and right click and select "copy" Go to Escribe/ tools/ apply service pack. When the window opens showing the other sw's right click and select "paste" to add your sw from the desktop. Once in there select it, you should now be good to go.
Taledski Posted September 29, 2018 Report Posted September 29, 2018 (edited) Any update on this? I had my Paranormal 250c updated with the "sleeptest" service pack. It worked fine for at least a week then the issue resurfaced. Edited September 29, 2018 by Taledski
Taledski Posted October 16, 2018 Report Posted October 16, 2018 Is there a new service pack that could fix the deep sleep issue?
Justdownload Posted October 31, 2018 Report Posted October 31, 2018 I approve. "DNA 250 Color v1_1_SP35_INT_SleepTest3.sw-service" and EScribe 2.0 SP18 has solved problem with sleeping of the Lost Vape Paranormal Box Mode.
1shootist Posted November 1, 2018 Report Posted November 1, 2018 I had the same problem, did the service pack and it was good for a while then it started doing the same thing of not waking from sleep, did the service pk once again and so far it's been working as it should. It doesn't really make sense doing it 2 times but it's working.
Augmentin Posted March 5, 2019 Report Posted March 5, 2019 Hi everybody I have my ThinkVape finder now for ten days and I have similar issue. It wakes up after sleep, but always after I change batteries it won't start until I put the usb cable in. i tried service packs which are posted here and all kind of configurations, but problem doesn't go away. is there some solution to the problem.? Thanks
Ghoulsfrank Posted March 5, 2019 Report Posted March 5, 2019 I didn't find any way. Most of the time if I click like 15-20 times to turn on the device after changing batteries it will turn on. I have already sent my device to evolv and it came back with the same problem. My other thinkvape finder doesn't have this problem
Wayneo Posted March 5, 2019 Report Posted March 5, 2019 @Augmentin @Ghoulsfrank What firmware version?
Augmentin Posted March 5, 2019 Report Posted March 5, 2019 7 minutes ago, Wayneo said: @Augmentin @Ghoulsfrank What firmware version? the latest ..I tried everything on Escribe. Ghoulsfrank .. Mine needs at least 10 minutes to turn on, no clicking helps.
Ghoulsfrank Posted March 6, 2019 Report Posted March 6, 2019 (edited) The latest one, SP38. When I click a lot of time on my fire button, the mod turn on most of the time. I see a weird glitch on the screen during a 1/4th of a second then I see my lock screen Edited March 6, 2019 by Ghoulsfrank
