epicwood Posted July 31, 2015 Author Report Share Posted July 31, 2015 I see some of you guys screwing the board to the side of a gbox or bbox, and i see the spacers. What length/diameter are the spacers, or where can i purchase them from? Link to comment Share on other sites More sharing options...
David247 Posted July 31, 2015 Report Share Posted July 31, 2015 Hi had to make mine from these http://www.ebay.co.uk/itm/400328192495?_trksid=p2060353.m2749.l2649&var=670413166611&ssPageName=STRK%3AMEBIDX%3AIT I used the m2 but you have to curve them of at the end so they don't touch the parts on the boardM1.6 screws 10 mm long and nuts Regards David Link to comment Share on other sites More sharing options...
macz Posted July 31, 2015 Report Share Posted July 31, 2015 epicwood said:I see some of you guys screwing the board to the side of a gbox or bbox, and i see the spacers. What length/diameter are the spacers, or where can i purchase them from? Search on eBay for spacer tubes, you can cut them with dremel if too long. Link to comment Share on other sites More sharing options...
RickAdair Posted July 31, 2015 Report Share Posted July 31, 2015 I used PFTE Tubing I had left over from a Bowden setup on my 3D Printer. Just cut it to length. Link to comment Share on other sites More sharing options...
VapingBad Posted July 31, 2015 Report Share Posted July 31, 2015 The USB socket is 6.7 mm long add a tenth of mm or two if you don't want this flush with the outside of the case, then subtract the thickness of your case for the length, cut them a little long and sand down to the exact length. On a Hammond 1590A I used 5.1 mm length made from some micro-bore copper water pipe/tube I had from years ago. Link to comment Share on other sites More sharing options...
epicwood Posted July 31, 2015 Author Report Share Posted July 31, 2015 Thank you all for the help. You guys rock! Link to comment Share on other sites More sharing options...
speed4mee Posted July 31, 2015 Report Share Posted July 31, 2015 You can also use nuts, so you can adjust the hight according to your liking Link to comment Share on other sites More sharing options...
epicwood Posted July 31, 2015 Author Report Share Posted July 31, 2015 speed4mee said:You can also use nuts, so you can adjust the hight according to your liking you said nuts...lol. Link to comment Share on other sites More sharing options...
speed4mee Posted July 31, 2015 Report Share Posted July 31, 2015 yeah, bolts and nuts Link to comment Share on other sites More sharing options...
blueridgedog Posted August 3, 2015 Report Share Posted August 3, 2015 In a pinch you could even use some hardwood dowel material from the local big box store. Cut to length, sand to final and drill to fit your mounting method. You could even epoxy this to the enclosure so it would take a screw to hold the board in. Link to comment Share on other sites More sharing options...
Willy Posted August 4, 2015 Report Share Posted August 4, 2015 I did something similar but I used square aluminum tubing, I made my posts .195 long, this is the tubing I picked up at the local RC shop Stock# 83010 http://ksmetals.com/25.htmlThe screws came from old hard drives I stripped down and salvaged the magnets from, the screws held the little pc boards of the HD's and are in varying length, all measure .065 or 1.65mm diameter. These self threading screws bite into the four sides of the tubing and you can hold onto a square easier then a round tube when tightening the screws. I used three screws from the back side of the board to hold the posts to the board then three more screws through the face of the mod into the posts. This is a Hammond 1590G I straighten the sides and corners on, I'll also include the pic of the 3M double sided tape I used to mount the screen, this is the tape they use to glue the screen's on ipod's, it works very well and is cheap on amazon.NOTE: I wouldn't trust this setup as the only ground for the board, chassis and 510, I soldered both the 510 and battery B- right to the pads on the board. Link to comment Share on other sites More sharing options...
VapingBad Posted August 4, 2015 Report Share Posted August 4, 2015 Lovely job Willy Link to comment Share on other sites More sharing options...
blueridgedog Posted August 4, 2015 Report Share Posted August 4, 2015 Nice work. I will have to build a metal one soon. What battery? Link to comment Share on other sites More sharing options...
Willy Posted August 4, 2015 Report Share Posted August 4, 2015 blueridgedog said:Nice work. I will have to build a metal one soon. What battery?I used this 1000mAh from Hobby King, I could have gone with a little larger battery for this box but I pulled the trigger early on while waiting for the boards and before doing in depth research. I figured I better order "something" in case there was a mad dash and batteries were suddenly hard to find, ended up they over sold and it got back ordered for a month anyways LoL. I repeatedly requested HK cancel the order because I bought a Flight Power while waiting but they sent it anyways.http://www.hobbyking.com/hobbyking/store/__11901__Turnigy_nano_tech_1000mah_3S_25_50C_Lipo_Pack.html Link to comment Share on other sites More sharing options...
Willy Posted August 4, 2015 Report Share Posted August 4, 2015 VapingBad said:Lovely job WillyThanks to you! You get the credit, I stole your ideas! Link to comment Share on other sites More sharing options...
VapingBad Posted August 4, 2015 Report Share Posted August 4, 2015 Willy said:[QUOTE=VapingBad]Lovely job WillyThanks to you! You get the credit, I stole your ideas! [/QUOTE]We all share ideas, all standing on each others shoulders so to speak. Link to comment Share on other sites More sharing options...
blueridgedog Posted August 4, 2015 Report Share Posted August 4, 2015 Great so the HK Turnigy 1000 we have been putting into plastic print boxes will go in the 1590G. Link to comment Share on other sites More sharing options...
Darklyspectre Posted August 4, 2015 Report Share Posted August 4, 2015 Honestly I am thinking of just using square pieces of high strength fire resistant MDF we use in the store. We got like 50 slabs of that stuff so I can mess up as much as I want haha. Link to comment Share on other sites More sharing options...
bunnsnow Posted August 26, 2015 Report Share Posted August 26, 2015 epicwood said:I see some of you guys screwing the board to the side of a gbox or bbox, and i see the spacers. What length/diameter are the spacers, or where can i purchase them from?I use these 1.8mm ID Silver tubes combined with some split lock washers and nuts and it works a treat. Link to comment Share on other sites More sharing options...
Mikey Posted August 27, 2015 Report Share Posted August 27, 2015 I had some small luck finding some #0-80 1 inch spacers on Amazon, but at $25 bucks for a box of 20 I passed on them. Instead, I got a package of #0-80 nuts and some e-z lok thread inserts that I can jb-weld together, worse comes to worse. Check out the e-z loks, they are intended to be used as a threaded insert for plastic but I'm thinking they will work just fine. I'll post some pics up here once they arrive. Definitely a cheaper, easier option it seems... Hoping it works! Link to comment Share on other sites More sharing options...
jrfhoutx Posted September 10, 2015 Report Share Posted September 10, 2015 I have some #0-80 1/2" stand offs and some nylon #0-80 screws to fit them, you still have to cut them down to be the right length but they work fairly well, just JBWeld or epoxy them in place... @Willy - Nice work. Man, I wish I could cut a USB cutout that clean, always end up a bit too big... @blueridgedog - There are quite a few batteries that will fit a G box I have a 1350mah 25c that fits pretty well... Link to comment Share on other sites More sharing options...
KomengzX Posted September 13, 2015 Report Share Posted September 13, 2015 just wandering, if i want to use bigger screws for example 2mm diameter, have to drill the hole to make it fit.is it will affect the ground connection between top layer and bottom layer of the PCB? Link to comment Share on other sites More sharing options...
Willy Posted September 13, 2015 Report Share Posted September 13, 2015 KomengzX said:just wandering, if i want to use bigger screws for example 2mm diameter, have to drill the hole to make it fit.is it will affect the ground connection between top layer and bottom layer of the PCB?Good question, when I looked closely at my board there appears to be a sleeve, a lining in the hole connecting the top and bottom pads. Link to comment Share on other sites More sharing options...
UKDTweak Posted September 13, 2015 Report Share Posted September 13, 2015 I used a kit from Stealthvape to mount my DNA200:http://www.stealthvape.co.uk/evolv/DNA200-MOUNTING-KITHad to grind down the sleeves a little as i had little space in the 1550p but worked a treat Link to comment Share on other sites More sharing options...
laadam Posted September 14, 2015 Report Share Posted September 14, 2015 That is a good kit. Wish something like that was available in the states Link to comment Share on other sites More sharing options...
