DNA75 escribe?
It does 75 & 200, there is a check box field on each material to mark it as temp sensing and if that is not checked (it will be for existing wires) and you use it in a profile it automatically goes to power mode.  There is also a matching material type called Watts, these are just to make it less confusing.
Level is battery level in percent.
my man......thanks.
I'm going to wait till Evolv suggests that we try the beta DNA75/200 software before I try it again. (I took out the earlier one almost immediately). As much as I would like to use it I'm going to wait, my devices currently work just fine.
Interest:
EVOLV 2016.05.02 DNA75 datasheet:
Output Current, continuous.........................30.0 Amps
Output Current, instantaneous peak.............32.0 Amps
EVOLV 2016.05.06 DNA75 datasheet:
Output Current, continuous........................ 30.0 Amps
Output Current, instantaneous peak..............40.0 Amps
HCIGAR 2016.05.02 DNA75 datasheet:
Output Current, continuous.........................50.0 Amps
Output Current, instantaneous peak.............55.0 Amps
What's more?
Regards
 Share
