Grandad Posted July 21, 2016 Author Report Posted July 21, 2016 Hi all is there not a facility to put USB current on the DNA75 whilst its charging, just a prefrence i like to see i know its on the 200 ?
dwcraig1 Posted July 21, 2016 Report Posted July 21, 2016 Gee I had to look, it's there under the screen tab in the charging fields. It took a moment to switch from temp to current on the mods's screen but it works.It does't show device monitor though only on the mod's screen.
Grandad Posted July 21, 2016 Author Report Posted July 21, 2016 dwcraig1 said:Gee I had to look, it's there under the screen tab in the charging fields. It took a moment to switch from temp to current on the mods's screen but it works.It does't show device monitor though only on the mod's screen.Thankyou dwcraig1 appreciated
Grandad Posted July 21, 2016 Author Report Posted July 21, 2016 Ive change the settings but still cant get what amps my battery is charging at @dwcraig1
Scarab Posted July 21, 2016 Report Posted July 21, 2016 Check display brightness in "charging mode". If you see warning "Brightness is too low" your display just off after timeout and you see nothing.
Michael Hancock Posted July 21, 2016 Report Posted July 21, 2016 I have not been able to get this while charging. I do not think is a option but I'll look again today.
dwcraig1 Posted July 21, 2016 Report Posted July 21, 2016 Well it appears not to work, I can get it to only display 0's, thought a first it was full charged so I ran it down some and still 0's
VapingBad Posted July 21, 2016 Report Posted July 21, 2016 No the charge chip does not provide an input current reading so the board cannot show it, it's normally around 750-800 mA.
Grandad Posted July 21, 2016 Author Report Posted July 21, 2016 I looked at the DNA200 settings and assumed the 75 would have the same option but thats not the case, Thankyou all for your replies much appreciated
mactavish Posted July 31, 2016 Report Posted July 31, 2016 Wasted a lot of my time on this. Very few of the options you can choose "when charging" make sense to me. Like "ohms", since I'm CHARGING, why would I care to see ohms, I can see the ohms of an attached atomizer by clicking the fire button. OK, we now KNOW the more useful option of seeing the USB current is NOT AVAILABLE, as it is on the DNA200, and yes it would be just as useful to see on a DNA75 device as many chargers are not 1-amp chargers, and even if you know and use the right wall charger, many USB cables often don't deliver the proper current. Seeing this information directly on the device would be helpful. Many don't have separate devices to test USB cables and chargers as I do. So looking at what is available for the three on screen slots when CHARGING, I use: BATTERY PERCENTAGE BATTERY VOLTAGE But don't see any other choice that is useful, so for now I made the third choice: "ROOM TEMPERATURE", just for lack of a more useful option! Anyone have a BETTER idea for the 3rd choice? If so what would you suggest and why? THANKS!
gratefulbuddy Posted July 31, 2016 Report Posted July 31, 2016 I agree completely, mactavish. Instead I am using board temp instead of room temp because, like you said, lack of a better option.
Spector NS5 RD Posted August 1, 2016 Report Posted August 1, 2016 i have my 75 charge screen set up >board tempbatt voltagebatt %
Swainesmatee Posted August 1, 2016 Report Posted August 1, 2016 I sold it but I could have sworn my vt75 was able to display a charging current like the dna 200
VapingBad Posted August 1, 2016 Report Posted August 1, 2016 Swainesmatee said:I sold it but I could have sworn my vt75 was able to display a charging current like the dna 200It has a field called current, but that is the current to the coil.
sciha Posted September 20, 2016 Report Posted September 20, 2016 ChunkyButt200 said:i have my 75 charge screen set up >board tempbatt voltagebatt %were you able to do it on hcigar vt75?
sciha Posted September 20, 2016 Report Posted September 20, 2016 Got it, it only reflects when disconnected on escribe. Thnks'!
