Gavnaf
Everything posted by Gavnaf
  1. Version 1.5.0
    582 downloads
    I am glad to inform you that I am back! I present to you my new theme. It is based on a theme from box mod lost vape Thelema.
  2. Version 1.0.1
    641 downloads
  3. This is a design theme. In the theme editor, you can remove this signature. Or change the subject to another. The mod shows that the charger is disconnected.
    The settings that I put in one screen, to which you go by pressing one button, you made on three different unreadable screens, which you still need to get to. Very confusing menu, strange choice of colors, small print. I am preparing a modified version of "Argus 2.0" where the same settings will be placed in one tab of the main screen. In my themes, I always try to make the interface as friendly and fast as possible, but you confused everything so that you yourself had to draw labyrinths in the description.
  4. Version 1.0.6
    366 downloads
    Design inspired by VOOPOO Argus mod. The bars in the center of the screen are a battery indicator. Дизайн вдохновлен модом VOOPOO Argus. Полосы в центре экрана являются индикатором заряда батареи.
    Great style!
  5. Version 1.6.0
    531 downloads
    I am pleased to present you a refined, clean and very stylish theme. Nevertheless, despite the fact that the design of the main screen is very clean, this theme has a wide range of settings in the "Edit Profile" menu С удовольствием представляю вам отточенную, чистую и очень стильную тему. Тем не менее, не смотря на то, что дизайн главного экрана является очень чистым, данная тема имеет большой спектр настроек в меню "Edit Profile". Потому что, те темы, которые вы хвалите за хороший функционал, вызывают у меня кровь из глаз своим дизайном.
  6. Version 1.2.0
    352 downloads
    The combination of blue and black shimmers when the display is tilted
  7. Thank's !)
  8. I will be pleased if you leave a link to the original skin in the description. Subscribed to your updates, it's nice that people liked this. I will be glad to help you in solving some issues, if they arise in you, write in messages.
    It's very nice that you decided to use my Arctic Fox theme as a basis. You got a great design, keep up the good work and try to create your own interface.
  9. Version 1.2.0
    1,403 downloads
    Big power font, Custom light)
  10. Version 1.6.0
    1,062 downloads
    Arctic Fox skin, Big watts font, simple lock screen, custom blue light )
  11. Version 1.5.5
    293 downloads
    5w switching step, Big power font, Custom light)
  12. I tried, everything is monolithic. Try unscrewing the three screws holding the connector, then pulling it up, it will easily come out, look inside.
  13. Hello, in my paranormal nothing shakes. try to disassemble the connector, maybe something foreign is inside.
    приятно видеть, что люди пользуются моими обоями) по поводу темы, хз как по мне, русский шрифт очень колхозно смотрится, плюс я б вообще старался текста избегать, лучше заменять их иконками. замок на экране блокировки - не лепится как то, нужно пробовать другой, мне оч нравится прозрачный из гауджеста, оч красиво смотрится) следи за сочетанием цветов, старайся не перегружать, также и за текст скажу, экраны кажутся перегруженными и не читаемыми, на маленьком экране мода это наверно вообще пздц.
  14. unfortunately, kantal is not suitable for any thermal control mode. This is a feature of this material, it does not change its resistance with temperature
  15. Version 1.0.0
    111 downloads
    The theme is taken out of the box mod MYUS SS5
    I have changed the color of the bottom elements, you can use them if you are interested. Biohazard_by_KnoRke_v1.1.ecigtheme
  16. Lanzarotechris You are very attentive, but there is a nuance, I launched the program on the standard settings, without the device). Regarding the voltage off: I see no reason to indicate this item, the battery will no longer give me the power I need at a voltage of about 3.3-3.4
  17. Hi, this is very easily solved, in the setup program on the graph of the batteries, pull the first slider down a little to set the voltage to 4.1, then the charge display will be 100%, but in general this is normal
  18. кстати я заметил у тебя под отображением еще какой то объект находится, это тоже может влиять, лучше не накладывать один на другой
