Everything posted by Frank65
Hello Loxias Happy you like my theme. Maybe the DNA firmware (the theme is just aesthetic , you cannot decide data refresh time or modify the logic) has a lower refresh of Device Monitor. So I think the lag on preheat indication is not something you can modify and it's common to all themes. Maybe you can try a simpler theme and see if it reacts faster... ?
Hello @CK1 , you have to (I assume you're using windows o.s. ) : Connect your device to a pc via usb cable Locate on pc where the file is (file extension is .ecigtheme ) Double click on this file , a small window opens On this window click button "Yes, Install" Wait until the file is uploaded Enjoy 😀
Yes you can , and as far as I know there is no risk in using users made 75c themes on 250c (except maybe some lack of functions). You can always revert to default theme. Enjoy your new device 🙂
There are many excellent themes , pick up some and try 😀
Yes you can : (from Escribe) Theme -> Save Theme
Hello It is related on how the cursor moves in the theme screen. I mean , with automatic , the cursor starts from the upper left objects and ends to the down right one. You can set it to manual and assign a numerical tab index to each object , if you need a different functionality. Hope this helps.
@sakuThis is the theme you uploaded corrected. Adding replay is a longer effort ... good luck temp.ecigtheme
That means you have two controls under same conditions with different sizes. You have to check and resize them.
anybody having connection issues
Frank65 replied to robert ferragamo's topic in EScribe, Software and Firmware
Hello I had connection problems only when using bad usb cables , changing those solved my problem. -
Hello and thanks for the feedback. The difference between the old and new version on replay function are only aesthetic , I mean I just replaced a picture with another one. The condition (which turn the ready pic on) "Coil can replay" is the same , and it comes from firmware not from my (or any theme). I doubled checked this So sorry I cannot help .... don't use kanthal on replay ps : tonight I will try to put on a ka1 coil and see what's happen ...
How to set default state of an object hidden by a toggle
Frank65 replied to niandra3's topic in Themes and Custom Screens
Try this test.ecigtheme -
Hi,there's a control in Theme Editor which shows last puff time in seconds: Recordings->puffs->time
Hello , to find the watts field under "replay ready" field , you have to RIGHT click in the zone and then click on "select other control" window until you find the coil power control. Coordinates are 0,48 , don't know if this may help. I'm a MTL user , so i'm vaping with very low wattages , that's why I'm using 0.5 watt . Temp should be already 5 degree steps , isnt it ?
