embe71
Everything posted by embe71
  1. What do you mean? There is no "combination" and no cycle. Save puff saves the last puff you took and tries to reproduce it exactly as it was.
    Really great theme! The only thing missing IMO is the warmth-setting for replay on an atomizer-profile.
    Simply the nicest looking theme I've used so far. I also love the amount of options/infos.
  2. Thank you very much for editing. Unfortunately it still shows the same error when trying to upload it on a 75C, so I guess it wasn't (just) the powerbank setting.
  3. Great! Really looking forward to it.
  4. Could you please make the theme compatible with DNA 75C mods because I really love the look of that theme? If I try to upload the theme via theme-manager I get an error message that the firmware of the MOD (Lost Vape Mirage 75C with newest SP) doesn't support features of the theme. I guess it's the powerbank setting...
  5. Could you please make the theme compatible with DNA 75C mods because I really love the look of that theme? If I try to upload the theme via theme-manager I get an error message that the firmware of the MOD (Lost Vape Mirage 75C with newest SP) doesn't support features of the theme. I guess it's the powerbank setting...
  6. It would be also nice to be able to change the material on the profile-screen like many other themes offer... Great idea and nice theme but I also would like some more controls like the material mentioned above.
  7. I don't think so: The "boost"-feature also required theme-support and was released with a new stock-theme by Evolv. Any other (user-)themes had to be changed accordingly after release.
    A very nice design, but there are a lot of screens and settings missing: TC-mode, profile, material- and temperature-settings etc. For TC-vaping it's just not usable unfortunately. It would be great, if there was a version with more screens and all options.
    My new favourite theme with this newest version. Easy to read. much functionality. With some minor adjustments by myself just perfect for me. Thanks!
    One of the prettiest and best readable themes out there IMO.
  8. Well, then it's just not 100% in reality: 4.2 V is rounded up anyway and there in most cases there is a certain amount of discharge/not completely charged when charging because you don't hit the perfect spot to stop. I get "99%" from time to time and think it's pretty accurate using a curve for my LGs.
  9. Great! Now it works. Thank you very much,. I like it even better than my own BW-theme
  10. Just noticed that the font seems to have some problems: Sometimes there are appearing whitespaces between the numbers (e.g. battery charge or amps) where there shouldn't be any: e.g. "7 1 %" instead "71%" or "12.2 1 A" instead "12.21 A". It seems to be related to char "1" at certain positions in the string. You can even see it in the screenshorts here: Take a look at the date and the "17" in the lock screen.
    Absolutely love it and it's good to see some more black-on-white themes. EDIT: Just noticed that the font seems to have some problems: Sometimes there are appearing whitespaces between the numbers (e.g. battery charge or amps) where there shouldn't be any: e.g. "7 1 %" instead "71%" or "12.2 1 A" instead "12.21 A". It seems to be related to char "1" at certain positions in the string. You can even see it in the screenshorts here: Take a look at the date and the "17" in the lock screen. Would be nice if you could fix that or embed another font which doesn't have this problem.
    Sterne: Eigentlich 4,5, aber die gibt es ja nicht. Farbgebung, Icons und auch den Rest finde ich sehr gelungen. Das alles gefällt mir wirklich sehr gut. Einziges Manko: Die Schrift ist mir zu klein, so dass ich doch bei einer Variante des Therion 75C Themes bleiben werde. Auch wäre es noch schön, auch einen Screen für die Kurven aus der Statistik der Züge zu haben. Da sieht man immer schön, ob die TC + Preheat wie gewünscht funktioniert.
  11. I also use SS316L Claptons exclusively (26/32 AWG) and can confirm that though the cold resistance is now read fine on my Therions (75C), the vape ist very weak and the temp control kicks in far too early. But: On my Therion 166 (DNA 250) these coils work fine while on the Therion 75C they don't. Either using single coil (about 0,5 ohm) on an Kayfun 5 or double coil (about 0,25 ohm) on an OBS Engine. The wire is from Coilmaster so it's SS316L for sure...It doesn't make a difference if I use a steamenginge curve for SS316L or the built in material for SS316.
  12. I know. But because it's a menu-bar icon which invokes the stats-window it should disappear not minimize (as it does in the windows-version, too). Just as Adobes Creative Cloud Central for example.
  13. @James, I'm running Sierra as well. But I got a suspicion: I don't know what I have set for "Minimize windows into application icon” in the dock-settings. So maybe it's related to that. I'm at work at the moment but can check this at evening (differten time zone here, Germany).
  14. Same here. Either I have to up the temp or manually have to up the ohms (to a higher value than it actual is) to get the same vape as with my Therion 166 (using a Therion 75C). Reading cold ohms and stability is fine though. Attached e-cig-file: Using Profiles 1-4 with SS316-Coils (Kayfun 5 and OBS Engine). Michas Therion 75C.ecig
  15. One little bug with Ecigstats (or two if you count the website in): When closing the stats-window the menu-bar icon is gone too and no stats are recorded. I know the windows-version behaves the same and one should simply minimize the window but in the mac os version "minimize" doesn't make the window disappear but instead minimizes the window in the dock where it is visible all the time which is not the way it should work. Further most oft the Ecigstats website content (stats etc.) doesn't show when using Safari as browser (Chrome and Firefox work fine). Apart from that no bugs found. Great work!
  16. Version 1.6
    688 downloads
    Ein inverses Therion 75 C Theme (deutsch), das drinnen und draußen recht gut ablesbar ist. Basiert auf dem Theme von DJLsb Vapes.
