Everything posted by BillW50
Reauleaux will only turn on when initially connected to USB
BillW50 replied to dusk1911's topic in DNA 200 and 250
If the voltages were all over the place, it would be time to get a second opinion from a meter. I can't think of anything left except maybe post a snapshot of the Device Monitor of it firing. The only thing after that is opening a ticket with Evolv. -
Yup, the DNA200 sleeps and won't wake from a fire button press. What does EScribe's Device Monitor show for cell and pack voltages? And do you have a digital/analog meter around? -
You can drag and drop into notepad, open notepad and selecting the drop down file type and lots of other ways, including adding .txt at the end.
I think they are the same. I don't think there is a difference. Here is one for Samsung 25R Samsung 25r.csv "Battery Charge (%)","Cell Voltage (V)" 0,3.02999997138977 4.00538539886475,3.24000000953674 5.94076061248779,3.3199999332428 8.84382343292236,3.40000009536743 18.0410633087158,3.49000000953674 27.2467193603516,3.55999994277954 45.6622352600098,3.67000007629395 73.3002395629883,3.90000009536743 84.4623031616211,4.01999998092651 96.600471496582,4.07999992370605 100,4.13000011444092 There is no difference for the number of cells that I can see. What does yours look like (open with notepad or something)?
Feature Request: More battery meter flexibility.
BillW50 replied to OldSalt's topic in EScribe, Software and Firmware
No we get it. I understand perfectly what you want. You want the pack voltage displayed as a battery bar. -
Submit a support request, email to: helpdesk@evolvapor.com
You can have battery percentage, pack voltage, and a third choice displayed on the screen. -
Showing a cell or pack voltage shows you the battery fluctuates during a vape. The battery percentage is the same display as the battery bar, except it shows in digits instead of graphic. -
I have cell 1 as one of my displays. You can use pack voltage too, but for me I have to divide by 3 or 2 in my head. So I see dynamic reading on all of mine. I do wish the battery level monitored voltage instead of watt hours though. Maybe a toggle could be added through the software. -
I feel the same way as CB does. I wouldn't say a battery is bad because the DNA200 says so. I too would want a second opinion.
Just to add what ChunkyButt200 has said... I wouldn't be to quick to judge a new battery that hasn't been used yet. Sometimes they just need a bit of exercise before they come up to speed. After a few charge and discharges, then see how it is doing.
@black lace: Once the DNA200 sees one or more cells as unsafe to charge, it won't charge.
dna 200 latest update showing temp name under each profile
BillW50 replied to sadavis73's topic in DNA 200 and 250
Yes, but it is easy to change it the way it was before under the screen tab in EScribe. Don't forget to upload changes back to the device when finished. -
I am not sure if having the puff counter is important or not on the display. But JaI Haze and myself have it displayed. I couldn't get any of my DNA200s to mess up the puff counter while removing the batteries and putting them back in. I assume most DNA200s act this way while using TC. It only started happening once I vaped in wattage mode, then removed the batteries and putting them back in. Now the puff counter reverts to an earlier count. Now TC mode puff counter does exactly the same thing when you remove the batteries. So far, just the puff counter reverts and nothing else is wrong yet. But connect up to the USB and perform a hard reboot and now the DNA200 can't read cell voltages correctly anymore.
Two 18650 charged to 4.09v GND = 0v Pin 1 = 4.09v Pin 2 = 8.18v Pin 3 = 8.18v No batteries on USB power only GND = 0v Pin 1 = 0v Pin 2 = 4.83v Pin 3 = 4.83v Scoped it and yes, it is a flat DC level.
You had the USB connected the whole time, didn't you? You didn't vape in wattage mode and then remove the batteries, did you? Once you did the above without USB power, now TC puff counter will reset once you remove the batteries. It never happened before in TC mode unless you do the above first. Now you connect it up to the USB and EScribe. Now do a hard reboot. Poof!
As luck would have it, I have been logging the puff count on all of my DNA200s for months. I've been doing it because I wanted to see how much ml of juice I use per battery charge. Virtually everybody compares battery life to hours or days of vaping time per charge. That doesn't help others much, since everybody vapes differently. But knowing how much juice one uses per charge is far more useful to everybody. I didn't know if collecting the puff counter would be important or not, but I logged it anyway. So now I have all of these logs of ml used, battery voltages, and puff counts. Not once did the puff counter ever miss a single count in all of this time, even with battery swaps. It just never happened. But JaI Haze was seeing it. Not only on one, but even on a repaired one. It turns out that the puff counter in TC mode never screws up, even with zillions of battery swaps. It only starts to screw up if you are in wattage mode and then you swap batteries (something I never remember doing). Now not only does it revert to an earlier count, but now in TC mode the puff counter screws up the same way. Now and only now, a hard reboot will not revert your settings. Instead it loses the ability to read the cell voltages correctly.
Fine, that is annoying but understandable. You failed to see how it can't read cell voltages is related to the puff counter? And you failed to make the connection how performing a hard reboot causes the cell voltages to read incorrectly? Well it is obvious to me. Cause the puff counter to mess up, then do a hard reboot. Poof! Can't read cell voltages correctly anymore. I have 5 working DNA200s right here. Want be to get the puff counter to act up and do a hard reboot on them too? @retird: Yes I did a Restore Defaults. It does restore defaults (doesn't change the temperature protect show/no show), but doesn't fix anything. Hard Reboot is suppose to revert settings. But all of the old settings are still there.
That is what it looks like to me. I have five more perfectly working DNA200s to run in wattage mode, change batteries and watch the puff counter screw up. Use a TC coil and watch the puff counter is now screwed up in TC too. Do a hard reboot and now the DNA200 won't fire since it reads the cell voltages incorrectly.
No retird, saving a ecig file, disconnecting and unplugging the USB, change batteries, reconnect USB and upload ecig file to device, the puff counter still jumps back. Although just having USB power and changing batteries, puff counter behaves correctly.
Nope, I haven't cracked it open yet and I probably don't have a lot of time tomorrow to do much either. But I wouldn't be surprised I'll find what others have found. That all the voltages are good going into the ADC. And it would be a good guess that some gate or amp opened or shorted inside of the chip during the Hard Reboot.
@VapingBad: No, I was talking about all of the people who post here of having the problem of their DNA isn't reading the cell voltages correctly. Sure, I first thought they must have had a bad cell in their lipo. That happens from time to time. But a few of them have digital meters and the lipos are fine, just the DNA isn't reading them correctly. So far, those of us here don't know why that happens. But this time, it happened to me. And it happened during a Hard Reboot with a messed up puff counter. Now if the rest of the other failures also did a Hard Reboot before everything went to hell... well guess what? Maybe nobody should use Hard Reboot until Evolv figures it out. Otherwise they they be receiving more dead DNAs and having more upset customers. I am sure they don't want that. Yes so true about the puff counter is often ignored. I too wouldn't have bothered logging the puff count except I was curious about battery life. And the good news is that the DNA200 wins as far as battery capacity vs. per ml of juice used. I didn't know whether I would need the puff count in this research or not, but the DNA had it so I recorded it. And I know the puff counter works perfectly in TC. I had no idea about wattage mode, since I rarely used it. And as far as blaming the lack of saves... that is minor compared to blown DNA200s. The DNA200 probably uses an A/D converter (ADC) to read the cell voltages and converts it to a digital value. Things were working right (except the puff counter) until a Hard Reboot command was issued. Now it can't even read cell voltages correctly and makes the DNA200 totally useless for most users.
JaI Haze, you didn't cause any problems for me. You opened the door for me to see a huge warning about using Hard Reboot. As under certain conditions it can ruin your DNA200.
