Well I don't see anything to do except to contact the vendor to get it replaced. Either that or Think Vape or open a ticket with Evolv. It would be interesting to know the cell voltages and what the graph looks like under EScribe's Device Monitor while firing and one while not firing to see if it thinks the fire button is being pressed down.
I've been experimenting with my seven DNA200 and always locking the resistance works great. I mean locking it and always keep it locked unless you change the build. I just started playing around with 5 clicks to lock and that seems to always remember that it is locked when you swap batteries. I haven't experimented whether it helps with remembering ohms or not yet.
And you can see the wattage drop on the display or you can tell that the wattage drops by the vape? Can you post a snapshot from the Device Monitor showing the pack voltage, power, voltage, and live ohms while it is firing?
What kind of coils are you running there? Kanthal? And what kind of wattage are we talking about? It almost sounds like you are running temperature control coils.
Oh I think they are going to have to fix this for real. Anyway I know if you always lock the resistance and leave it there, it remembers just fine. Changing through EScribe probably works too, since it saves it to the memory. But if you do that, all you need is USB power while changing the batteries and it never turns off that way too.
Yeah if you do it just before the battery swap, it doesn't do it for me either. You have to do it a bit earlier and use it for awhile. Then swap batteries and then it remembers.
I lock the resistance my HCigar VT133s, Reuleaux DNA200s, and Lost Vape Triade mods before I swap batteries and it seems to help a lot. Of course unlock once you swap the batteries.
Yes Vambo, I too have one DNA that drains one cell too. So I know it happens. I suppose you could open a ticket with Evolv. But heard that VS customer service is really great too.
Only one thing left Zrat, open a ticket with Evolv. http://helpdesk.evolvapor.com/index.php?a=add You could try with Wismec support too if it is within the warranty. But I never heard of one single case of that doing any good.
Because I thought you knew they were not non-TC Claptons. Plus Firefox wouldn't let me in for the past 12 hours. Error 400: Header or cookie too long. Turned out the cookie was too long.
Well if it is the fuse, you know how that goes. Sometimes they just blow for no reason. The middle of last year, Evolv got a batch of fuses that didn't hold up well and that didn't help matters either. If you own meter, you can check to see if it is open. If you can solder small pads, you can replace it too.
Phil Busardo showed how Aspire lithium batteries are made. They bake their batteries in an oven for two months weeding out the dangerous ones. [video]https://www.youtube.com/watch?v=dOaE4K_ByiA[/video]
That sure sounds like the 510 pin is dirty (if other attys act the same way). And if that isn't it, the wires inside going to the 510 connector is flaky. What kind of mod is this?
Is this a rebuildable? If so what model? And what kind of DNA200 is this? In EScribe -> General (tab) -> Profile (the one you are using) -> Atomizer Analyzer. This gives you a live update as long as the fire button isn't pressed. What does it read before firing and after?
