Everything posted by GHammer
multiple ui Gauges - Major update 2.0.0
GHammer commented on SirTimmyTimbit's file in DNA 75 Color, 100 Color, 250 Color
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- replay
- minimalstic
- (and 10 more)
- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
Here's the memory usage info from the newest Gauges. Don't know how it compares. I wonder where the off-board memory is?
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
I likely missed it, but what theme were you running? I don't have the problem using the latest Gauges.
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Regarding the wattage being changeable from the main screen. I like it being that way. Why? I vape two flavors in two 'identical' tanks. One works best at say 30W, the other works best at say 25W. When I swap tanks, I read the resistance and then play with the wattage a bit to get the vape I like. As long as the wattage is still changeable from the main screen when not Playing, cool. If it were read only while Playing, fine. No reason to change your 'perfect' puff after all.- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
I use Steam Crave Supreme V2 (the one that looks like a baby Plus). I have 2 single wire coils in each tank. I run 27 ga SS430. The tanks come in right around 0.318 as measured on the mod. My mods are set to 5% difference to ask 'New coil'. I have not seen a problem with resistance on the Paranormal 250c, nor a Vapecige 75C in TC or Wattage Replay mode. Just trying to say if you are seeing oddities with resistance, try troubleshooting the tank and coil first.
- 4 replies
- dna250c
- paranormal
(and 1 more)
Tagged with:
Glad you got it figured out. I too am(was?) a TC only vaper. Until Replay. Then I was doing TC Replay and was told that while it works, Replay was meant for power mode. So, I gave it a try. I'll likely never go back to TC as this gives me better flavor and most importantly, more enjoyment of vaping.
Just to make sure you get Replay try the instructions for getting to a known state regarding Replay. Once it's working for you, then you can experiment with other themes. Replay (International Edition only). To use Replay: (1) Apply the Service Pack. (2) Choose a profile to put Replay on. Check "Use Replay on this profile", and name it how you like. (For most people, the easiest way to use Replay is to choose a profile whose material is Watts.) (3) Load on a theme with Replay support. (The default theme has Replay support. Go to the Theme tab and click Default Theme, and upload.)
I pulled my batteries for the night. This morning, I had Replay, puffs, everything except time and date. Seems to be the way it is from the three people who tried.
Ok, I'll bite. I'm off to bed and I'm removing the batteries from my mod. We'll know in 5-6 hours.
No thanks. I don't show the clock on my mod and just wanted to let you know that it would be a capacitor not flash memory that is needed to make a clock that keeps time during battery removal. Larger capacitor, longer it can go without battery. To be fair, many people never remove the batteries, using USB for charging either LiPo or 18650s. If an accurate clock on your mod is important to you you'll have to put the spare set of batteries in service while another is being charged. Or USB charge the mod. With a fast charger brick you should be able to get 2A charging into a 250c I'd think.
I don't know. I have multiple sets of batteries, so the mod is never without power for more than a minute or so.
Not flash memory, but a capacitor. Other mods with time display use this and it works. I just used my yardwork Cylon after 2-3 weeks and while the time was off by 2 minutes, it still was there. I change batteries once daily. I don't rush through it, but I'm not going for speed either. My Paranormal 250c has not lost the time/date during battery changes.
- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
Just for fun, since it isn't doing productive work right now. Take a small screwdriver and tighten the screw in the 510 pin on the Plus. I have several tanks come to me with that screw a wee bit loose and it cause all sorts of grief until as a last resort I tried tightening it. Now, it's part of getting a new tank. I'd also spin me a new set of coils and perhaps replace the grub screws. If none of that produces results, go ask Maggie Luo at Steamcrave for a replacement base. They have been really good with replacement parts for me over the years.
Can't speak for the Titan, but I love my Supremes, Supreme V2s, and Pluses.
Not really, I have had tanks that just refused to vape on a certain mod. Mainly tanks that were other than stainless steel. Seems the coloring/paint would cause all my VT133s to fail, but worked fine on my VT167s and other mods. Doesn't really help in your case, just to let you know that it can indeed be related to the tank even if it works elsewhere.
I'm sorry to hear all the problems. I'm VERY happy I didn't pull the trigger on a Boxer or Rebel.
Just wanted to say thanks for the Replay mode. I have always been a TC vaper. No use for power mode. I've been known to forget to open the JFC on occasion. I also like the consistency. I have been using Replay mode in wattage on my 250c and 75c for a few days now. Wow! This is an excellent vape! Get the same puff time after time but without the steep power ramp down of TC. I vaped a tank completely dry and just got a warning along with no vapor. With wattage alone, I would have gotten a dry hit. Plus, though it's likely due to knowing it is different, but the flavor seems to be noticeably better. If Replay can make a wattage vaper out of me, it's sure to be a winner.
I had Replay 'working' in TC mode. Then, I was informed that Replay was meant for wattage users and would work best in that mode. Setting my profile to 'Watts' didn't produce any vapor, just the Check Atomizer warning. After a bit, I decided to try a different method to get Replay working as intended. I use SS430, so was using that as my material. When I did that, the mod was somewhat confused. I saw Temp instead of volts on the display and could only change Temp from the main display, no wattage. I think it worked, but as TC is solid I couldn't really tell. Anyway, I changed my settings. On the mod tab, I chose Allow dubious coils and unchecked Support only temperature-sensing coils. Then I set up a profile to use Replay in power/wattage mode. And, it works a treat. I have wattage displayed for change, and see volts instead of temp. Plus, it works as shown by device monitor. No temp displayed there now.
replay Material-ish Ocean - DNA75c - DNA250c Optimized
