Everything posted by 67exec
It only does the 100w for ~1sec as part of the boost feature or during replay.
- 1 reply
- 1
Places to buy DNA 250c Enclosures for custom builds
67exec replied to shroomalistic's topic in Modders' Forum
It seemed like the easiest way to me. -
Thank you
On 4s, with a phone inside for GPS speed, she'll do 62mph before she goes airborn. That's about 3/4 throttle.😎 she can pull 2 5yr olds in a wagon for an entire parade route on a single 5000mah 4s batt with power to play at the end
@gizman, I didn't find a battery by my prefered manufacturer to fit your bill. My dislike for Maxamps came from my rc experience running my 15lb monster. 3 separate times I had Maxamps 4s lipos crap in less than a month, plus they couldn't deliver the amperage I needed from packs rated 3x what the max of my esc is. SPC Racing was my brand of choice until they closed up shop, now turnigy seems to be the only packs that can reliably feed my beast and hold up for over a year. It's a nitro revo converted to electric. Mamba xl extreme esc with datalogging, castle 1717 motor from XO-1, diffs from a losi xxl, and 1/4" keystock with impact wobble sockets for driveshaft.
I wouldn't buy anything that contains a Maxamps battery, or anything that recommends them. They are low quality cells at a premium price. They offer a lifetime warranty, but I could replace a better quality of a lesser price at least 3 times for less money and hassle.
Post some pics, build, 510, etc. It's way easier to diagnose when we can see things
Should have been heat capacity, and that is how long it takes the coil to heat up and how long it stays hot after you quit applying power. According to steam engine your coils have what I consider to be a relatively high heat capacity for a 22mm dripper, and probably borderline even for a 24mm dripper
Have you tried less power? What gauge is your wire? Heatflux could be your issue
I've been using the plus for just over a week on a self built 250c with the gauges theme and have yet to run into any issues. Dual 26g wrapped in 0.3mm x 0.1mm ribbon. All 316l from Lightning Vapes.
I'm happy to report that the aromamizer plus works great with replay. Dual26g wrapped in 0.3x0.1mm ribbon all 316l from lightning vapes. 3mm if 6/7 wrap .22 ohms. -
I have to have a single fold over clip, because in the summer, it fits in the cargo pocket on my shorts. The rest of the time it hangs on the outside of my pocket, and as a mechanic, so lower is better. Plus, with a decent clip I can roll around on a creeper w/o worrying about it falling off.
You have to hook it to escribe and set it as a 3s battery. Otherwise, default is 4s
I buy those super cheap Ozark trail knives at Wal-Mart specifically for the clips. For a fold-over design, they have the stongest grip I've found short of an old discontinued kershaw clip that I used to have.
I just broke my original ammit, made up some dual 28g fused claptoned w/34g all 316L, 5wraps .286ohms. Replay has been doing stellar, chainvaped the tank dry. It's been heaven, hoping the aromamizer plus works this good.
Have you cleaned the threads on the 510 of the paranormal? Lost vape had some coating on some of their 510 threads where atty screws in.
OK, So WHEN is this NEW software for the 75C coming out?
67exec replied to Joe M.'s topic in DNA 75 Color and 100 Color
Hardware is pretty much the same, but firmware is vastly different. -
It simply shows that currently they believe that the hardware isn't where the health concern is. Hopefully it will be a model that continues long into the future.
Replay works with temp control capable materials. I suggest ss316l, ss430, or possibly ss304 as those are safe to use in wattage mode. Ti, and ni200 would require you to use escribe to enable replay for their respective tc profiles.
What is the core wire? Ss316l, ni80, kanthal, ti, ni200?
You obviously have no r&d experience -
Deal with a b and n1 vs gxl2 is that the top on the gxl2 is flat, where the other 2 Have the front and rear edges are rounded. Width wise all of these boxes will hold a 30mm atty. It appears that on the b and gxl2 l, the center of the 510 is exactly 15.5mm from the front and both sides. 30mm atty on the b gives the appearance of a front overhang even though it's .5mm from the edge. Of that makes any sense -
4s 1600
