black lace
  1. Possibly when you take the back off it and stick your nose in its guts it works fine, is the back touching somthing when fully asembled. Like shorting accross the buttons or a tiny bit of swarf tumbling about inside will cause real big problems, post up some pics our mate
  2. have only heard good things on here about Vaporlips, rule of thumb is x3 on lipo mah compared to 18650's, so to match a 3000 mah lipo with 18650's you would need to find 3 x 3000mah = enough to get 9000mah, hope that aint as clear as mud but not getting to scientific a lipo is three times moor efficient.
  3. I wouldnt be put off buying one just because of the op's requirements because it has a 1amp built in charger, a couple of half hour blasts on that thoughout the day...ect
  4. I can vape all day at 30 watt twin coils on a 1300mah lipo not in temp mode, i reccon in temp mode i would get a lot better performance out the battery, i probly use 10 /12 ml of juice in a day, i would say doubtfull, at 100 watt on a 1500 lipo, and re think my coils, to a bit smaller but same heat your after, but would bring the power down a bit.. what do you vape on at that?
  5. Or try the house insurance new for old. I dont know what the turn over is for sending stuff in, but sending a board from uk then back again has took 5 weeks, replacement factory board though, soon got it fitted and running, built several dna 200's now and had two duff boards, buying from secondary outlets, will go direct from now on..
  6. It would be good if it was locked to the top of topic list and then you could add to it as and when..
  7. I agree A lot of thought went into the design of it. And the designer may have liked to move his wattage to reach temp, hypertheticaly if the designer was a non vaper , perhaps he would have made it switchable, People have got different i dears thats for sure.. i'll start a new coil on an rta at 430 and according to escribe im vaping boarder line that value reached but rarely get the mod flashing temp protected. Other folk just wack the powerbon and blast away. After a few days of vaping i up the temp and wattage to get the same draw and thats an indication to me it needs new wicking..
  8. check out posts by (jaquith) he is very much a coil and wires guru on here, im sure he wont mind me saying..........
  9. Finally got a replacemant, it took about five weeks from start to finnish and then a few hours to solder and fit, and get it running, i still prefer built rather than brought but what a pain in the neck.. you never get any discount offers for your trouble or even a slip saying with compliments ect..
  10. Might pay off to also leave it for a few hours after a reset, for board temperature stabilisation.
  11. Aint got a clue mate just following the recomended, when i check resistance on escribe it says do not lock. I will have a bash at that coil as a single but unfortunatly i have .40 nife 30, but still nife.. i did try stainless and followed all the info i could find, and thought it was all very over rated, like a far better tast from the juice... custard had under notes of haddok or mackrell, it does your head in, spending hours trying to improve.. ect
  12. Blimey, thats twice as much i i was thinking, what guage wire and what size mandrell and how many wraps, also just notised your op, dont think your supposed to lock resistance!
  13. Good luck to ya, ive got some nife 30 to have a bash with tommorrow night, there are quite a lot of posts on the site regarding metals other than ni200, one bloke, forget his name right now and its difficult to swap between pages while only using my mobile, but hes prety adamant that the preheat works well for ni200 but it can be obstructive when trying to use ss, ti , ect. Cant see that youve got antything to loose by trying it without to start with. Like allready said, default is full 200watt
  14. If you restor defalts you will be on 200 watt for one second pre heat. From what ive been reading your preheat needs to be off..
  15. Build anouther coil or try anouther atty, why would the programing that youve inputted change but still say the same as it did a week ago when it worked, coil and connections..
  16. Sorry should have mentioned there is nothing outher than the fuse serviceable on the board.
  17. Some of the posted up ones are good, some i dont believe the poster has tried them because there poor, there is also a link to a guy whos done some really good ones, am on mobile at the moment, when i get to a computer i'll post a link, .. you need to create a file in your documents. Call it.. say.. evolv stuff. .. then when you click on the screen pic you like, click save.. save it to your evolv stuff folder.. then as above.. when in escribe select load, find your folder, set what you saved to it.. dont forget to finnish off by selecting upload to device from your tool bar in escribe.. also when finnished select disconnect..
  18. Sez me sitting here vaping with 3 mods to the side of me, two being 200's , with an absolutly butiful little puppy on my lap that ive had for christmas.
  19. ""Yeh but no but yeh"" ""i think"" with your camera explanation the film can only ever be the juice as a medium for two exples..Its got to be for the decision of the user realy because: say bring a .25mm wire up to temperature with 12 watts, but to bring .50 mm wire up to the same temperature in the same time frame will need 24 plus.. which brings me to the bit about why was there a screen shortage for absolutly months. Surly if the dna200 was your flag ship device and main source or hopefull main source of bread and butter money in your pocket, surly one would procreate several other alternatives within days, possibly even of different sizes, with user programable format, like whats being disscused above,, the first thing i noticed was the themes are the same for all profiles, i thought there was a problem with my escribe program and over writ it anout three times. The forum and programs got launched and adjusted and tweeked for a few months but nothing since. This time last year i said i wouldnt build any 200's main reason was because i didnt understand lipo batterys, but i was using the excuse that evolv move the goal posts so often theres no point because a 150 watt with fixed screen and twin 18650's would be moor practical and mod builder friendly and would probly be along shortly, dont get me wrong ive built six, two boards where basket cases so got sent back, which is anouther £10 plus a month waitng, calling it an early adopters forum and not working or comenting on idears that are coming up to the surface, compared to the initial first months, looks like the bosses have done a runner..
  20. Or general discution, topic title ::: custom themes imgage gen application .. is an awsome contribution..
  21. Page 5 of show off your custom screens has the you tube walk through..
  22. Look for them through paint brush, microsoft paint...
  23. Screen and board turned up today.. so got to find time to re build... that is the thing i cant get my head round.. plenty of boards with screens and units going out to factories ect but no spare screens as is, and a manufacturing shortage for over six months, surly a different manufacture would produce them within a few weeks, the last ones where about £5 each..
  24. on an rta I adjust both upwards but only as the coil and wicking becomes blocked and codged up with use, to maintain the same vape so it makes no odds to me anyway. im so finely perfectly balanced I never reach the max value ive set, am allways a few degrease lower lol,,, each to their own,,, but if its only a programmable feature I think they should be adding and updating as requests and idears go in, like what els can we give them for their money, and other folk can see how dedicated we are and whant one ..........ect don't want to be part of the temp debate over watts and heat but I changed my temperature protected screen, the wording never rely sat with me.
