Thought there was somthing next week, you dont know anyone with a bunker do you?? Lamo
Oh ok, Had a delivery of nico and flavours today (panic bought) -- buttery butter,, one drop on top of custard as a preview.. oh my gosh..
When i get time at a pc i will have to do some homework..never heard of anything like it, (heard of doughnuts) but (chips) or am i in a compleatly different field. what ever, make sure its fastend down well for a good connection and start low.. low temp low power.
Ok then, find out for sure your coil material, (asuming you have updated to latest firmwear) lock the device and press all three buttons, fire and up and down, after a few seconds you will be promted to scroll to whatever material coil your using.. see where that gets you.. the reason i asked about the juice, some factory built coils are wicked so tight anything heavier than 70pg wont flow. important about your coil material,,, you wont get 'kanthal' to work in temp mode..
Am on mobile at moment our mate, i did try and open the file but cant, are you using stainless pre made (factory produced coils), if so turn your pre heat right down to zero or off if you can, please list your :- 1 Atomiser 2 coil material 3 state weather coils are factory built or you have made them. 4 juice viscosity eg - 70/30 vg/pg ect
Most people only take about a 4 second drag so turn your preheat down to 1 second 50/70 watt, your not saying wether your twin coiling an rdta or single coiling an rda or rta. Or even what material coil.. you must have escribe to know your preheat, because of the lack of info (no disrepect), i can only suggest my own, try a temp of 380f ish and start at 15/20 watt and work your way up. sounds like you need to recoil rewick.
Theorum TC issues after Crown and TFV4 issues...
black lace replied to footbag's topic in EScribe, Software and Firmware
have you tried dripping a bit of juice down the spout to make sure your coil is evenly and constantly wetted seeing as your confirming steady resistance your connections must be (ok) Also now that your upto date on firmware, why not try the pre set values. Lock device and press all three buttons then scroll up or down, select stainless ect. I think stainless is a real b**** to work with, and its too time consuming for me, i like plug and play Ni200/Nife30, but i can replicate what your describing with a dry coil. -
Resistance still climbs while it's supposed to be locked?
black lace replied to p8ntballa9362's topic in General Discussion
bad coil & or related connections, also make sure your putting enough power through in the first second of fireing to trigger the temp, somting like 100degres plus -
Fair play. Probly better off just incase of other hidden issues..
Might be a bit late now if your mind set on sending it in, but there are a few threads on here regarding fitting an automotive fuse,,, you may have to le'ase between your electrician mate and evolv regarding still sending it in if things still dont work out,,, but it may be a quicker fix, because of your location...
I dont know, just make sure you send buy an insured recorded postage at the value you paid. and also photo copy your recipt for the mod, because obviously you will be sending a recipt in with the mod,,, so you still have some proof of purchase.. hope that aint as clear as mud.. all the best to ya..
Edit...oh good grief.. got you mixed up with the op .. har har ..(mobile small screen). i never said. When the fuse whent on mine, it had been charging for a few hours and still connected and charging and the atty i had on it was so codged up and coils in such desperat need of rebuilding, it would read short when tweaking the fire button, then intermitantly fire. So two contributing factors a suspect charger and when my coils start shorting, i now change them out sharpish.. good luck to ya...
You can pretty much visualy tell if the fuse has now blown, I dont know how fiddly it is on yours to replace insitue, put an rma request in if your not confident,, ive done one on one of my builds, (fiddly) i never definatly got to the bottom of what caused it to blow, but the charger haddnt fully charged it for a few nights so i binned the charger and the mod is still fine after months of use..
Ive never seen one say ohms too high, what attomiser are you using? Are you building your own coils for it? And sos 3 questions, what metal for the coils?
Good for you, since i stopped smoking and took up vaping i havnt hoiked a single lugie,,, that is grounds enough to take up the fight..
And any coments toward the vape shops id like to see closed down, first put yourself in the shoes of an educated observer. Watching the owners fleece and brainwash wanabee quit smokers start up vapers with sub standard clone mods destined to break and juice made in who knows where containing who knows what.
[QUOTE=Laguz75]At one time I sold tobacco pipes to a head shop that the pipes where ment for other things but if I called them what there ment for I would get in trouble. Any person who condones crimianl activity is a criminal.
no dont think so, eight vape shops in a five mile radius i am happy to board up myself, rules and regs are for the safety of the user and manufacture.
Okay but i know of a few vape shops and internet flavour supply that i would like to have a hand in closing down, being told that a flavour or juice is ""subjective "" when it has clearly been made from fox urin gets no support from me.. and the same goes for pile of rubbish mods, its allways the honest person that has to take it on the chin when the wheels get knocked off the band waggon. Bikker amongst yourselves..
Am i missing a few threads on this or has someone misenterpreted mom&par as a manufacture and likend term of frase to themselves. what ever it is the whole thread has gone to male hen.
Sos am on mobile, keep flipping in and out,,,, i sympathise with you, but i can only bring the conversation full circle, ""it needed policeing,,,the uk is awash with clone dangerous devises and juice that contains who knows what.. but like allready said by myselfe and the start of the thread, heavy handed is an understatment.. i cant go into the polotics its been done over time again allready, i dont even follow my own .UK. so no nothing about .US. clawing back lost revenue from tobacco ect my greatest fear was, anything containg nicotine would be regarded as a pharmacutical.
Is it a twelve month license? or a one off fee payable back as a percentage off proffit of earnings,
it may make the mesh in the net a little tighter to prevent cloners slipping through, but to design and produce a product goes way over, this is why you see the leading chinese market names using this product in their device.
Made in america and nothing hidden and well maintained has a lot going for it. there has been an incredible amount of flooding of the marked of substandard products over the past two years, a certain amount of policing should be welcome. a legit company regarding anything has to carry the burdon of working allongside regulators in order to thrive.
Dont know where the op got to but i thought he was taking the mick several weeks ago..
