Everything posted by dwcraig1
Of the posts that I've seen relating to the Lion 1800 mah battery that comes in the Vapecige the actual capacity is around 1250 mah to 1300 mah.
Stupid quesiton, but..
dwcraig1 replied to MikeTheVapeDude's topic in EScribe, Software and Firmware
It's in post #1 of "early firmware" -
Newbie with TI TC/TCR Questions
dwcraig1 replied to VapenHippie's topic in EScribe, Software and Firmware
Wire gauge and number of wraps isn't part of the equation, only the wire type when using one type of metal. -
I have two of the hotcig dx200 batteries, the one that came with the mod and an extra from Fastech. Both arrived healthy. no complaints, I have an Opus also to compare to. just saying as there were a bunch of bad Hotcig ones.
That my friend is no easy task and a bit hard to put into words. Both covers need to be off, guide it in from the right side (looking at the screen) wire end first, keep the plug hanging out the other side till the battery is near in place. Get the plug in and put the battery all the way in. The large wires exit the battery opposite the board. Kind of a generic answer but the best I can offer. The balance connector gets put in place first actually, plug the big ones together early on during the process.
I thought the deal was to stop making cloned Evolv boards if they were to do business with Evolv. Maybe I'm missing something here though.
There is a small torx head screw under the label just above the two banana plug holes just below the " + and -", the cover just slips out from there, just a tab in a slot at the top. https://www.fasttech.com/forums/3372100/t/1845693/got-it-yet/1 (post #16)
^^^ if your thinking about using this battery it won't fit. http://www.hobbyking.com/hobbyking/store/__8936__Turnigy_1300mAh_3S_25C_Lipo_Pack.html The battery that Evolv sells is the correct dimensions. $19.99-FullyMax FB900HP-3S You can find it else where for less.
Kangside, the maker of the original Vamo
KSD is starting to ship
**Request** Firmware Version
dwcraig1 replied to DireHavok's topic in EScribe, Software and Firmware
It's in the bottom right corner of device monitor in EScribe. -
I replaced mine with a Turnigy 1300 but ended up that the Lion Power battery was OK, just unbalanced. Take a look at this post: /topic/67772-topic/?do=findComment&comment=910038
Reuleaux DNA 200 Screen Ribbon Fix Yes/No
dwcraig1 replied to Teehippster57's topic in DNA 200 and 250
Just a comment about when I fixed mine. As I was pulling up the screen up all I could think about was " gee this is stuck on there pretty good, I hope that it doesn't pull any components off the board with it". And it did not. -
Thanks
How does one go about setting the current to zero in EScribe?
I took near 10 minutes to do mine only because I'm paid by the hour (did it at work) LOL -
I thought I'd do mine here at work but don't have a small enough Philips screw driver. I did look at the tutorial and suggest putting tape across the up and down buttons and face plate prior to removing the face plate to hold them in place. Here is the link to the FB page: https://www.facebook.com/groups/1057199624324956/ EDIT: I do have a precision straight edge screw driver set here at work so I used it with no problem but I did need some assistance getting the screws started back in, that was accomplished using the same round tooth pick that I used to fold the screen back as a screw starter. Done, easy job. -
I shall have a look at mine tomorrow.....providing it makes it through work. -
I'll throw out what I've noticed, the fire button appears to be in the same spot but the screen, up and down buttons and USB port are not so another face plate is needed. Edit: I see it now, just the screen position appears a bit off.
Sorry, I see that you stated that already in the first post.
There are at least 3 NiFe30's available and they all have a different setting, where did you buy yours?
My dna 200 reuleaux Battery reads dead
dwcraig1 replied to BILLYROCK's topic in Manuals, Instructions, and Tutorials
The first thing I'd be looking at are those rings around the positive connector for the batteries. If the wrapper is to thick or the positive button on the battery doesn't protrude as is should no contact will be made. This is how they did the reverse battery protection (with the rings). The rings should be left the way they are and the battery replaced or corrected (if that's the cause) If just the two inside batteries make connection the board is still able to power on but not vape...BTW -
From their web site: "Dear WISMEC Customers: Breaking news! Because we are now limited by the capacity and supply chain of our materials (screens), we cannot possibly meet the huge and evergrowing demand for the Reuleaux DNA200. In an attempt to satisfy this enormous demand, Wismec will be launching the Reuleaux RX200. The RX200, a new version of the Reuleaux series, designed by JayBo, still retains its unique feature of three removable 18650 batteries and reverse polarity protection. However, the new and powerful chip utilizes on board reverse polarity and has maximum output of 200 temperature controlled watts. These temperature functions include Titanium, Nickel and Stainless Steel modes. The new and proprietary chip has upgradable firmware and comes in new color options and can be easily distinguished. Click:http://www.wismec.com/product/reuleaux-rx200/ to find more details about the Wismec RX200. Thank you for your time. WISMEC Marketing Team November 23rd, 2015"
Sounds like good advise to me. I have zero complaints as to how well it works especially at the wattage I use. I have 1 dna40 board left, maybe I'll build something with it.
