dwcraig1
Everything posted by dwcraig1
  1. I like this question......a lot.
  2. Try a different computer and/or a different cable. Get these things eliminated and let us know the results.
  3. That 3rd cell reading is normal I would set the soft cell to 2.9 volts and subtract about 10% from your watt hour calculation. (about 20 watt hours) The 28.51 sounds like what 3 cells would be. Why less watt hours? the battery was rated between 2.5 - 4.2 volts, you will be using 2.9 - 4.2 volts.
  4. Is there any possibility that there's e-liquid on the balance connections on the bottom of the board?
  5. Just one example: the cable may be defective
  6. A couple things besides something wrong with the board. Have you tried using a different cable? In EScribe, device monitor, diagnostics tab there is the ability to set, turn on/off charging...can you check that it is set to charge? Also is battery set to LiPo and not power supply?
  7. Gee I thought I did this on my 75, I couldn't get it to work earlier today on my 75. I see I posted a live view of it a few posts back. Hmm
  8. This is using a Vt133, single core 26 gauge Kanthal wrapped with 34 gauge Kanthal (dual coils) in Aromimizer v1. Firing at 70 watts, 110 preheat.
  9. OK give me a minute, I'd say that the temp is way out of whack though.
  10. Credit and kudos to gorman
  11. I certainly hope so, pick one that has a for real CDR of at least 20 amps.......or higher. http://evolvapor.com/datasheet/dna75.pdf
  12. Losing charge while sitting, check for flux on balance connections. (or any where else)
  13. That would be like trying to put 16 oz in a 12 oz bottle, even if you could squeeze it in there it would fit really tight with no room for swelling...not good.
  14. To me #6 - 11 on the list are candidates for the Hana 200
  15. My laptop has 3 usb ports, one is integrated with an eSATA port. With a power only cable I got .5 amp with one, .8 amp with the other and 1 amp from the one that's integrated. With a data cable it's .5 max on all three. Oh, I checked the cable using a 1 amp wall wart and it can due 1 amp OK.
  16. I found this much, /topic/68472-topic/?do=findComment&comment=915836
  17. Being in the US certainly makes it easier to send it to Evolv than from other places. I believe it has a 1 year warranty. A DNA75 has the reverse polarity built in to the board ...if 75 watts will do you. http://helpdesk.evolvapor.com/index.php?a=add
  18. And it fits inside the Lavabox?
  19. Just to add to the above ^^^ When the mod sees a data path the max amperage is 500 ma.
  20. Making it easier for future use. SMY_SDNA75_Stock_settings.ecig
  21. Here's a good place to find info on them, just keep in mind that they are not 35 amp CDR and most likely 20 amp batteries. They should work just fine with in their limits. https://www.e-cigarette-forum.com/forum/threads/efest-purple-35a-3000mah-18650-bench-test-results-only-a-20a-battery-equal-to-hg2-and-30q-though.711203/
  22. That would amount to a work around fix, if it's acually .12 ohm there is something wrong.
  23. The mod resistance is far from the expected setting. Might have a bad solder joint on the 510. Is the 510 center pin on the mod at normal height, not stuck down?
  24. If your asking how to change it to .CSV here: open file in notepad, select "save as" from drop down menu. Add .CSV to file name. Save as "all files". Load to Escribe and upload to device.
