dwcraig1
Everything posted by dwcraig1
  1. Early released firmware is found here... labeled "Early" This works with all EScribe DNA devices. /topic/66731-topic/?do=findComment&comment=900119 Recommended software for 75/200 is here: https://downloads.evolvapor.com/SetupES75.exe
  2. The fuse is to protect you from the battery not to protect the board. At least put in a blade fuse inline on a battery wire. Do it for you. You can buy the original type fuses BTW
  3. $10....no $1 should satisfy that situation.
  4. Well when I ordered my DNA250 custom from Evolv I had to do an age verification check using the last for of my SS #
  5. Best answer: https://helpdesk.evolvapor.com/index.php?a=add
  6. I'll give it a go. If EScribe is just opened and you put up the window to change the TCR of a particular material it will have .006 in the box by defaualt as well as show you the graph for that setting. Nothing is changed till you press"OK". If EScribe wasn't been closed and you have changed the TCR of a material then it will show that number in the box by defaualt. Again nothing is changed till you "OK" it
  7. Does it still appear to be draining the batteries when idle?
  8. No doubt...LOL
  9. Only in the form of a IPV2 or long gone Segelei 100
  10. I suspect it will do just fine with the SS right out of the box providing the right material is selected. Each one will need to be done separately.
  11. That's correct, I don't think it will contain much if anything "extra" for the 75 though. It (SP3) has some nice additions to EScribe though. Worth getting IMO.
  12. 1.0.56 is for the 75....and 200. 1.0.42 is for the 200 only
  13. The DNA75 does well with SS3XX Download for recommended EScribe is on this page. https://www.evolvapor.com/products/dna75 Otherwise you may use the SP3 "Early" from the 1st post of the Early software page. /topic/66731-topic/?do=findComment&comment=900119
  14. The latest software is always in the first post of this thread: /topic/66731-topic/?do=findComment&comment=900119 It is labeled "Early"
  15. So I did a little snooping around in EScribe, the only setting that I could find that would cause my battery icon to be empty on my vt133 was if I changed it from 2 cell to 3 cell. I guess you looked at this already but it's the only thing I found that effects the icon that way.
  16. I upload settings to get mine back after upgrading the firmware, have you tried that? Well I went back and read your 1st post again, I guess you did that already.
  17. I just got through 8 ml of juice, not a drop was left in the tank (2nd tank) of my Kayfun 5 with glass tank. Just after I hit 8 ml the next fire was with battery icon flashing. This is 40 watt, 50 wat preheat, my drags are just under 2 seconds so it was mostly at 50 watts. 3.6 ohm ss430. This was with an LG HD2, 2000 mah, 25 amp cdr, a 25r might do even better.
  18. Have you tried removing the batteries for a moment? Did any battery settings get changed in the process?
  19. I have no idea, back then I was checking on battery life. I generally keep it on the upper end of the charge never letting it get very low. Using a Kayfun 5 clone instead of Bellus, 40/50 watt @ 430.....it never throttles down (normally) I'll see what I can do about getting an answer for you.
  20. from CW"s site "Chemical Composition: Fe, <0.12% C, 16-18% Cr, <0.75% Ni, <1.0% Mn, <1.0% Si, <0.040% P, <0.030% S C Min - - Max - 0.12 Mn Min - - Max - 1 Si Min - - Max - 1 P Min - - Max - 0.04 S Min - - Max - 0.30 Cr Min - 16 Max - 0.18 Mo Min - - Max - - Ni Min - - Max - 0.50 N Min - - Max - -"
  21. I ordered their shortest spool of 430, 10 meters I think, they sent me two 25 meter spools. Maybe because I said why I was buying it...LOL
  22. I didn't notice anything regarding an off taste created by the wire it's self. That is actually why I bought it, I had read it tasted bad and didn't believe it so I bought some. I paid very close attention to how clean it was coming off the spool as well as if there was an odor given off when first heated. I found nothing unusual.
  23. As I said in a few posts back. I use TCR setting of 0.00238. It's a different composition than Unkamen's 430, CW's contains Ni for one. The TCR I'm using is one that I came up with after much experimenting (not a scientist, not even close).
  24. Yes I bought some of their 25 gauge SS430
