Everything posted by James
No? Where did you download EScribe from? The version on our website should do it fine. ( Although, as you observe, ECigStats communicates in the same way with all devices. )
It should work with the default install
Hmm. What version of EScribe are you running, and what firmware version on the device? (DNA 250 should run fine with 1.2 SP3 and later Service Packs.)
Fixed. Thanks for reporting that. -
Could you try a traceroute (tracert evolvapor-downloads.r.worldssl.net on a command line)? Also to downloads.evolvapor.com? Thanks! (Does your country censor Internet? The CDN would share an IP address with many other sites. Also, what IP address does your PC think that site is? Lastly, do you have any plugins in your browser/firewall that might block sites?) -
I've posted up 1.2 SP5. Please let me know if you run into any issues with it. Have a good night. James -
Hello MacVap, We moved to a CDN for our downloads, since the traffic is into the terabytes... I've contacted them and will let you know what I find out. James -
Screen Flashing & Escribe Error - No Compatible USB device connected
James replied to DC_VAPER's topic in DNA 200 and 250
If Connect and Download Settings worked, what did you try next that said no USB devices were connected? -
Battery Level to 0% after upgrade to 1.2 sp3
James replied to Nordic Ravn's topic in Batteries and Charging
skrilla, in Device Monitor, what do your cell voltages say, and what is the USB Voltage? -
When you used SP4, did it not automatically make the minimum 0.9? If not that's a bug
lewiss, if you go to Device Monitor and click Diagnostics, Set USB Current Limit, and set it to 1A, what does the USB current read? 1A, or does it stay at 1.8A? (You have the device set to "Wait Until USB Charge Current Goes Above": 0.9 (or higher) A, right? If it is set to 0.1, the default for DNA 200, this is the cause of the error.) I'd recommend using the SP4 Production Utility not the SP3, by the way. Its USB charging test is better.
At a 3.2V soft cutoff under load, it's not surprising you don't get significant vapor if the lowest cell is at 3.29V when not under load. Most of the capacity is at higher voltages, so it would appear to even out voltage-wise after a bit of charging despite having a large difference in charge level between the cells. (When they are very low cells tend to crater on voltage, so if the other batteries are at 5% and that one is at 0%, it'd appear a lot lower, whereas at 20% and 15% they'd appear similar.) I'd let it charge up to 4.2V and give it time to rebalance. It's not necessarily anything wrong with the pack. Balanced, next time, you should get closer to that 19% it thinks you have left.
The DNA 200 doesn't have the charging issue SP4 addresses. There may be a SP5 for DNA 200 at some point with other fixes. -
after update 1.2sp3 my VT133 show "Check Bat"
James replied to minnizbeer's topic in DNA 200 and 250
That sounds like an issue with the balancer taps, or alternatively, are you sure your batteries are seated correctly? -
I've fixed the link. Sorry about that -
This is part of the reverse battery protection. It won't pull any power from the port unless it sees a reasonable positive battery voltage.
Once the charge is complete (4.20V/cell unloaded) the DNA will correct the meter. If the meter is off, it may say 100% but until the cells actually get to 4.20V and the current declines to nearly zero, it's not actually finished charging. If you have a cell at 3.33V your battery is basically empty. The meter, when the DNA detects it should do a correction, always does it based on the weakest cell (since Weak Battery will limit on the weakest cell anyway, for safety). If the other two are that much higher, you need to let it charge and give it some time to rebalance the cells. -
salsadoom, the problem is that Wine doesn't have support for Windows's USB HID APIs. I don't think it'd be terribly hard for them to add. Presumably it's just that nobody's up and done it. Humorously, the C# HID library I use, HidSharp, actually does support Linux's native USB HID APIs (though Linux does require you to set udev rules to access HID devices on non-root accounts.)
The 1.2 version is much more portable than earlier versions -- a good 90% of the user interface is in platform-independent code, as opposed to perhaps 50%. As time has allowed, I've been moving more and more of the code this direction. Keep in mind though that time and resources are limited, and there's a lot more we're doing than EScribe. It'll get there.
I don't think the internal resistance has changed. 1.2 SP3 may have trouble reading resistances that low, probably due to some of the extra protection code we added. I'll have to look at it this coming week. Other than this issue, I am glad it is working well for yall. -
The results of Battery Analyzer only affect the battery meter. If you can live with a battery meter that is maybe 10% or 15% off, you really don't need to configure anything in EScribe for your batteries. Weak Battery messages are based on a minimum voltage, and charging goes to a maximum voltage. We did this intentionally so that accidental misconfigurations have cosmetic effects only. The safety-critical systems are not user-configurable. The battery *type* matters, but Lithium Polymer/18650 is already selected by default. Only if you are using LiFePO4 batteries (I thought people would want to, but it seems not) are you going to need to configure that...
Okay, I have just one simple important, and final question.
James replied to NickyGiaccone88's topic in DNA 200 and 250
There are no modes on the DNA. X watts is X watts... What material is your coil? If it is Kanthal, no temperature protection is going to occur, so you will get a purely power-controlled vape. The power level is related to the amount of vapor production. I'd try turning down the power. It may be much too high. You don't need to select Kanthal on a DNA device. We autodetect the non-temperature-sensing case. If it is a temperature-sensing wire and it is temperature protecting, disabling temperature protection is going to increase the amount of vapor. I'd try turning down power. -
The purpose of preheat is to raise the temperature of the liquid above the boiling point so vapor production can begin as soon as possible from the time the fire button is pressed. Kanthal has no meaningful rise in resistance with temperature. We cannot sense its temperature. Therefore, we do not preheat it. -
It sounds like one of your batteries is fully charged and the other is not. If one cell is at 4.2V and the other is at 3.8V, the DNA will need to rebalance the cells. This is very slow. It can only charge quickly if the cells are nearly at the same state of charge. Let it try and charge for about 24 hours, and see if the cells become closer. Once the cells are balanced you should be fine.
Do you have a mod resistance set? Maybe it is set inaccurately high. That can cause a cooler vape.
