Contact the Help Desk (link in my signature) or OXVA for a replacement/repair.
You can see it to change it, but it's not gonna show over on the left. Not even on the 75. https://forum.evolvapor.com/topic/71561-cheat-sheet-key-combos-for-dna60-mods/
Only on the 60 Color, not the b&w.
Boards are tested before shipping and they usually do a reset before shipping.
No, definitely not. It was changed at some time.
I do NOT believe so, and I can't explain the 1080 mAh value. The cell charges fully to 4.35V as shown for the 'Fully charged battery voltage' field.
No, not on this chipset.
You probably need to install Rosetta. Here's a link, and the instructions are down near the bottom. https://support.apple.com/en-us/102527
Use the link in my signature line and reinstall escribe and see if that works.
Read this: There is a loop in that theme. You have 4 options. Downgrade from 77 so it will load Hope the author fixes it (it shows exactly where/what the error is) Find another theme Fix it yourself (You already have it)
Boson DNA80C will not connect to Escribe software
Wayneo replied to Likethehat's topic in DNA 80 Color
Are you sure the 80C has connected and you got into escribe. My last idea/thought would be to make sure you're running the latest version of escribe (or since the 80C was released). Link in my signature line. -
Maybe try a reboot and different port on your PC. Failing that, wait for Evolv to respond. -
Try to find another cable with a longer metal part where it plugs into your 80C. Make sure it works on your 100C beforehand. -
What OS are you running and has it ever connected? -
OXVA Pro 2 DNA not charging (esuite software problems)
Wayneo replied to Alexpsy's topic in Oxva Pro 2 DNA
When did escribe stop working? What MacOS are you running? -
Charge your battery when it gets low.
Odin DNA250C consistently reads atomizer resistance higher than Pico
Wayneo replied to profess0r2000's topic in DNA 250 Color
Evolv never made one, but a user did. That's what I use, but another moderator uses the shorted 510. You should also do thermal calibration. -
SO YOU COMTINUE WITHOUT CALIBRATING YOUR MOD AND ASK ME TO COMMENT. And no, i wouldn't want to look at any csv, certainly not a Pico. The mod measures coil resistance, and now with more information (Terpometer? never heard of that. Exterior ceramic?). At some point (no other comments) you should open a Help Desk ticket. Link in my signature line. -
No idea if Dovpo made any changes from the evolv defaults, but you can run those yourself. As well as setting/checking the internal mod resistance. Who even knows if your Pico is accurate. Atomizer analyzer also showed you a temperature. Your mod uses that temperature to figure out internally what cold reading is at 70ºF for TC. You can see that in your TC profile right after the coil Ω's. -
Install and upgrade (software and FIRMWARE) with latest version of escribe? Link in my signature line.
