UPDATED VERSION 12.0
Updated - version 11
NO PC REQUIRED
@SirTimmyTimbit
Edited by BigLarry
Updated to version 11
What's New in Version 7.5 See changelog
Added info for 4 batteries under the Battery & USB Menu for DNA 250c mods that use 3 or 4 batteries.
Added a Power Bank function under the Battery & USB Menu for DNA 250c users.
I'm out of chip memory so it's a basic Power Bank function. Just an on/off & a status field that lets you know if it's active or not.
With version 7.5:- Download
