UPDATED VERSION 12.0
Updated - version 11
NO PC REQUIRED
@SirTimmyTimbit
Edited by BigLarry
Updated to version 11
What's New in Version 4.0 See changelog
ADDED OPTION TO DOWNLOAD THE 8 COLOR THEME WITH A GRAY BACKGROUND WHILE KEEPING THE ORIGINAL BLACK BACKGROUND.
BOTH DOWNLOADS STILL CONTAIN ALL 8 COLORS.
UPDATED THE ESCRIBE SETTINGS I SHARE WITH IMPROVED COIL MATERIALS & UPDATED THE BATTERY CSV IN ESCRIBE TO GET BETTER BATTERY LIFE.
- With version 4.0:
- Download
